HDV desktop hard disk recorder at DVinfo.net
Topics about HD production.
Old March 1st, 2006, 10:48 PM   #1
http://www.hdvrecorder.us/index.html
This is from the same company that distributes the Avio stand-alone NLE. The web site claims that this is a better way to store HDV footage than tape. I have a hard time buying that but it might be a good way to playback HDV edits without tape.
Old March 2nd, 2006, 11:10 AM   #2
while it looks great, if you think again, this is just a PC, with dedicated software.
for an average PC with a 250 Gig HDD, i doubt you have to pay 2000$.
For sure if you add the hassle of assembling it and paying for all the software needed, it still competitive for a plug and play stuff, but probably all the guys with an HDV camera already have a PC with about 200 gig of storage, so you had beeter to invest this moneu in upgrading you PC.
by comparison it looks cheap versus a firestore (holding only 80 gig ), but the lack of portability makes all the difference.
conclusion, would be nice to try.
Old March 2nd, 2006, 01:03 PM   #3
A laptop with HDVrack or the even the free videoLAN software is a far better solution, and far more portable.
Damnit Jim, I'm a film maker not a sysytems tech.
Ken Hodson is offline   Reply With Quote
Old March 2nd, 2006, 05:00 PM   #4
Another option is a Laptop + HDVSplit. I did not realize that it did capturing also, but it does. I tried it the other day and it works pretty well and was a lot easier to run and then start capturing than VLC.
http://strony.aster.pl/paviko/hdvsplit.htm
Michael Rich is offline   Reply With Quote
Old March 3rd, 2006, 01:33 PM   #5
HDVsplit supports only the Sony cams HC1/A1/FX1, but I think they ment to say tested with or why wouldn't they list the Z1? Anybody try to use it with the JVC cams? It also has huge system requirements, much higher then I found workable with VLC.
Old March 3rd, 2006, 03:43 PM   #6
Contributor
I think tapes would be much more secure for long term storage than any hard drive.
Old March 3rd, 2006, 03:50 PM   #7
Abso-stinkin'-lutely.
We recently had a power supply failure that allowed our drives to stay powered while the fans failed. We lost 10 drives in a RAID. None of them recoverable, both backups and main....
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old March 3rd, 2006, 03:53 PM   #8
Contributor
In the past 10 years I've seen a total of 3 scsii drives die and one firewire, for no apparent reason. During that same time I have never had a tape failure or even a dropout. Sony is claiming even better reliability for their XDCAM disks, and if a person must go tapeless, it seems to me that's a reasonable solution, in terms of cost and ruggedness.
Old March 3rd, 2006, 04:19 PM   #9
The cam still records to tape at the same time as all of the solutions listed above, unless you choose otherwise. A laptop with HDvrack while also recording to tape is an amazing battery only failsafe solution. I prefer to use an external usb 7200rpm drive with the laptop when plug-in power is available. Anyone know of a battery solution for an external drive?
Old March 4th, 2006, 12:38 AM   #10
What exactly are HDV Rack, VideoLan, and HDV Split used for?
Alex Thames is offline   Reply With Quote
Old March 4th, 2006, 04:13 AM   #11
As I understand it, this works with power supplied via USB, but is limited to using 2.5" IDE HDDs.
http://www.newegg.com/Product/Produc...82E16817145658
Robert M Wright is offline   Reply With Quote
Old March 4th, 2006, 12:08 PM   #12
Alex: HDV rack or DV Rack with the HDV PowerPack upgrade as it is officially known is an HDV/DV monitoring software. It displays what you your cam see's whether it is recording or not. You can choose to capture whenever you want so your footage is already on a HDD when your done shooting. Huge time saver. It has additional features such as zoom, vectorscope, waveform, user definable zebras ect...
http://www.seriousmagic.com/dvrack.cfm
VLC VideoLAN is a freeware mediaplayer that handles HD footage very well and has the added benefit of allowing live streaming so you can monitor your footage on screen (like HDVrack) and record it to the drive, but without all of the other fancy stuff.
HDVsplit is similar again, but I haven't used it.
Micheal gave the link to HDVsplit above, so don't be shy and have a read.
Old March 4th, 2006, 12:19 PM   #13
Thanks for the link Robert. Great price for that enclosure. 2.5" are just so damn expensive, would love to find a 3.5" solution. But even at that price $200 for a usb2.0 powered, enclosed 60gb to plug into the laptop would give you 4+ hours of recording.
Old March 4th, 2006, 01:37 PM   #14
You can use a 5400rpm drive for capture (I've done it). Make sure the drive is defragged though.
