#16 | |
Note these figures are for recording formats, the actual camera performance will depend in practice upon lens, chips, processing etc. The term 'pixel shift' is normally used quite specifically to refer to the front end of the camera, and a technique used in some cases (eg Z1, HVX200) to improve the luminance resolution over that which may be expected from simply looking at the pixel counts of the individual R,G,B sensors. |
#17 |
And in the end, it still doesn't matter on the display. Whether the PAR is 1.0 (which nothing sub 100k records) or 1.333 (HDV) or any variance thereof, the viewer only sees one of two resolutions on their screen, and that....is the point. Either it's pixel shifted in the camera, or it's resampled at the display.
Maybe someone somewhere, including me, missed the point of the original question. The reason that footage in the US was/is shot at 50i in the past was more a film cadence option than a resolution option. Taking the thread into the nether world of imager size and pixel shift isn't part of the original topic, so that's where the thread has gone awry.
Douglas Spotted Eagle/Spot Author, producer, composer Certified Sony Vegas Trainer http://www.vasst.com |
#18 |
It's not really about 24p vs. 25p, as some of the posts have suggested it's easy to convert between the two simply by using a 4% time stretch in audio.
#19 | |
The extra resolution is an added bonus, but it wasn't of much help to those shooting PAL for broadcast when they had to downconvert the res, given the tools available at the time. If they were doing film out, it was great. Some guys are still doing this. Additionally, the original question is regarding HDV camcorders, in which case there is no additional resolution, as there is no PAL or NTSC to contend with.
#20 |
MPS Digital Studios
I recently did a test converting Z1 footage shot in 50i/CineFrame 25 to 24p and honestly, there wasn't much difference in appearance--it's one frame away from each other, except my DVD player wouldn't play back 50i footage. So for me, converting to 23.98 is best.
heath
My Final Cut Pro X blog |
#21 |
Thanks for all the comments - the original post could actually be summed up as "Is there any point in shooting 24P?" If I have a 25P option I can't see myself ever needing 24P, and I don't entirely understand why it exists and why it seems to be a requirement of modern cameras.
#22 |
MPS Digital Studios
Simple: marketing for digital/HD filmmakers.
hwm
