HDV Audio: What would you rather have.... at DVinfo.net
Topics about HD production.
Old December 18th, 2005, 03:03 PM   #1
1. 384Kbps mpeg II audio that the HDV cameras can now record.
or
2. 44.1Khz/16bit .wav audio?
- ShannonRawls.com
Shannon W. Rawls ~ Motion Picture Producer & huge advocate of Digital Acquisition.
Shannon Rawls is offline   Reply With Quote
Old December 18th, 2005, 03:13 PM   #2
neither.
I'll take 48k/16bit or 48k/24bit over both for better sound, please, Alex.
(BTW, ALL DV, Panny HVX, XDCAM, VariCam, and most other dig cams are 48k/16bit)
http://www.vasst.com/search.aspx?text=HDV%20audio
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
Old December 18th, 2005, 08:09 PM   #3
Alex didn't say 48k/16 or 48k/24 now did he mr. contestent?? *smile*
Alex said 44.1khz/16bit.
Now...let's try again....
44.1khz/16bit vs. 384kbps mpeg2 audio.....which do you choose?
Old December 18th, 2005, 09:21 PM   #4
I'd still take the 44.1/16bit *IF* it's PCM, but you didn't specify the file format. If the file format wasn't PCM/uncompressed in the wav package, then I'd take the HDV over the 44.1/16 bit.
Back to you, Alex? <big grin>
Old December 19th, 2005, 07:31 AM   #5
Either way, if you're just recording dialog the difference is pretty much irrelevant. Music, maybe you'd hear some compression artifacts, but MP2 should easily be able to handle dialog without introducing anything that anyone would notice in the final mixed soundtrack.
Certainly I've never noticed any sound compression problems with my HDV recordings.
Mark Grant is offline   Reply With Quote
Old December 19th, 2005, 10:53 AM   #6
Same here. I usually encode the audio on my DVDs down to AC3 at ~192 Kbps anyway, so unless you're doing something which requires better I don't see much point in worrying about it. Others apparently feel differently, but that's my take on the issue.
Kevin Shaw is offline   Reply
