Is the HD-SDI output always pre-codec?
Couple of questions regarding HD-SDI:
- Is the HD-SDI ouput signal on cameras always created straight from the CCD (so to speak, I'm no camera expert) giving you pristine quality or are there cameras that convert video that's already compressed using their codec (HDV, HDCAM) to HD-SDI giving you loads of unnecessary data? - Also, do only HDV or DVCPRO-HD cameras allow realtime capturing of their compressed video via firewire? - AIUI, high-end compressed formats like HDCAM (SR) or D5 or always transferred via HD-SDI. Wouldn't a tape deck deck need to recompress e.g. everytime it records from another deck via HD-SDI, resulting in quality loss? Thanks |
CTO, CineForm Inc.
1) HD-SDI or analog compoent output are pre-compression, although there is a lot of processing after the CCD before it is sent out. Thisis the data you want for the best chroma keys or simply the highest quality.
2) Yes. 3) Yes, these deck do recompress, yet for D5 and HDCAM SR the bit-rates are high-enough that this is not a major concern. It is more a concern with standard HDCAM and DVCPRO-HD which have lower bit-rate and also resample the image over HD-SDI, so be warned.
David Newman -- web: www.gopro.com blog: cineform.blogspot.com -- twitter: twitter.com/David_Newman |
#3 | ||
There aren't any DVCAM (SR) cameras/decks that output compressed via firewire, are there? Wouldn't this solve the above problem? |
#4 | ||
CTO, CineForm Inc.
#5 | |
#6 |
CTO, CineForm Inc.
Oh, yes of course, HDV over FireWire that is what 99.5% of our customers are doing. Note: DVCPRO-HD is not currently support by Aspect HD, Premiere or Vegas, and no I can't say when it will either.
#7 |
Thanks David. Since you're obviously quite knowledgeable please take a look at another thread I started here about SMPTE timecode in digital video and how NLEs handle this..
