On board ND's - how do they work at DVinfo.net
Topics about HD production.
Old October 31st, 2005, 07:17 AM   #1
Contributor
Traditionally an ND filter on the front of the lens reduces the amount of light hitting the plate/sensor.
On videocams, how do the on board ND's work? Do they reduce the amount of light, or do they attenuate the gain on the sensor itself?
Specifically interested in the GY-HD100 but I imagine most cams use the same scheme.
John Mitchell is offline   Reply With Quote
Old November 12th, 2005, 07:40 AM   #2
They are physical ND filters that are moved in front of the CCD in the case of the FX1/Z1U. Gain control should be a separate function.
I would assume this was the case with the HD100.
-Steve
Steven White is offline   Reply With Quote
Old November 12th, 2005, 02:08 PM   #3
Barry Wan Kenobi
The DVX also has a physical filter wheel. I'd assume the JVC does as well.
Barry Green is offline   Reply
