Blurred background & sharp subject with FX1000
So after a few years of shooting in full auto, I thought I would try a few fancy shots. I was trying to get that shot where the background is sharp and subject is blurry, then transition so subject is sharp and background is blurry. I clicked my button from A to M with sweaty palms, but of course all this did was make the entire frame blurry and sharp. Is there a simple way for this manual-novice to experiment this shot?
Thanks all. |
Re: Blurred background & sharp subject with FX1000
you'll need to create as much distance between the subject and the background as possible, keep the camera farther away from the subject, and use the widest Fstop
Expanding a bit on what Darren wrote....
There is a lot to recommend an FX1000 & similar cameras, but shallow depth of focus is not something they're good for. This is due to the sensor size. At 1/3" on the diagonal it's relatively small, and this is a primary issue in getting shallow DoF. With a cam like this most things are mostly in-focus most of the time. With your cam, or any, these are the controls that can help make DoF shallower: Bigger sensors. Greater distances between subjects, or subjects & backgrounds. Wider lens apertures. Longer focal lengths. * Block a scene with, say, 12' between subject and background, and have some good detail in the BG. * Set your lens to full telephoto and find your framing by moving the camera back until it's framed as you want. * Using manual exposure controls, open the lens aperture fully, and use other controls to correctly set exposure. * Now you're ready to rack focus between your subject and background, usually with manual focus. It's hard to see how well you did until you look at it on a decent-sized monitor.
30 years of pro media production. Vegas user since 1.0. Webcaster since 1997. Freelancer since 2000. College instructor since 2001. |
Zoomed in a bit, yet a low F-stop number, something F-2.8 or lower if you're able. But you can't zoom in too much otherwise you're lowest F-stop will be around F3.4 or 4. It needs a bit of prep, and ideal conditions, if you're shooting outside you'll likely need filters or a high shutter speed to allow for a low f-stop, bringing in that much light you'd blow the shot out.
