HDV to Betacam SP decks question ... at DVinfo.net
Topics about HD production.
Old August 23rd, 2005, 10:17 PM   #1
Anyone done this before ?
I'm trying to find out if I can get the Sony HDV deck to generate sync-ed timecodes to a Betacam SP deck when doing a dub.
Cheers.
Do more, learn more
Wesley Wong is offline   Reply With Quote
Old September 7th, 2005, 06:18 PM   #2
Cheers.
you can find on the net simple lanc-rs422 (9pin-sony protocol) converter by addenda. it converts signal from lanc to remote, and systems like old avids can read that. i tried this with avid and it works, but unfortunatelly not for me, since i am in PAL country, and all lanc-rs422 converters i tried were for NTSC.
check addenda (about 80-90$) or TAO converter. (you can find price somewhere on the net - i do not have a link now) TAOs are more expencive ones.
if you want to copy hdv directly to beta with the original TC, then you can use either new convergent design converter for that (they have two devices for that) but both are expencive (at least in my opinion- aprox 1900$)
http://www.convergent-design.com/
or miranda hdv converter (dont know about the price)
or - cheaper way - to find (buy) horita converter (approx 250$) wich can transcode/extract TC embeded in rs422 signals to LTC timecode which you can connect to beta as external timecode.
but, then you will anyhow need that first mentioned converter from lanc to rs422.
if this is not clear - i can explain it in step-by-step manner.
thanks,
filip
in kino (sic!) veritas
Filip Kovcin is offline   Reply With Quote
Old September 7th, 2005, 09:34 PM   #3
wow.
Thanks.
Appreciate if you could enlighten me step by step. Thank you !
Do more, learn more
Old September 8th, 2005, 10:27 AM   #4
from hdv to beta with identical timecode
attention: this procedure was tested just with Z1 HDV camera and HDV player/recorder by sony.
1.find (buy) TAO lanc to rs 422 converter or addenda converter with same possibility (lanc-rs422) addenda approx. 80-90$ or cheaper on ebay, TAO approx 200$ (i'm not sure)
2. buy horita (http://www.horita.com/) translator (on their site was for 399$, but i bought mine for 117$ on ebay - (RLT-50 RS-422 to LTC Time Code Translator)
3. connect and plug LANC converter on back of your hdv player/recorder or on side of your camera via LANC (blue ring) plug. other side is rs 422 connector - 9 pin.
4. check your 9 pin cable - if nessesary find also 9 pin gendre changer (1$).
5. connect that rs422 side via 9 pin cable to horita translator. (note that you should use pinout entitled "remote"). Plug on horita translator :)
6. connect your LTC (timecode) output on horita with beta sp with BNC 75ohm cable (ltc OUT --> timecode IN on beta)
7. switch your beta to EXT timecode. Switch beta to ON :)
8. connect Y-U-V (component) output connector on HDV unit with beta sp component input. (you may need 3 small converters from RCA/chinch to BNC 0.2$ ea.). Swich display on your HDV unit that you can see TimeCode onscreen.
9. start (you must FIRST START HDV unit) HDV unit, THEN start REC on beta. wait until tape runs! you may notice also in a few whiles that tc is not correct, but after a short while it will jump to correct one. you must work in ASSEMBLE mode on beta.
10. check TIMECODE again on all displays - if correct ok. if not... hm, check cables first.
"schematics"
hdv-->lanc-rs422-->horita-ltc-->TC in on beta
hdv-->component out-->component IN on beta
hope this helps,
filip
