HD generally performs worse than SD lowlight? at DVinfo.net
Topics about HD production.
Old August 16th, 2005, 12:46 AM   #1
Do HD DVCams have inferior low light performance compared to SD DVCams?
I know the Sony FX1's performance is bad in low light but have no idea about the other models..
is it just the FX1?
Owen Meek is offline   Reply With Quote
Old August 16th, 2005, 03:44 AM   #2
Bad compared to what? See the following threads which deal with this topic:
http://www.dvinfo.net/conf/showthread.php?t=44458
http://www.dvinfo.net/conf/showthread.php?t=39865
http://www.dvinfo.net/conf/showthread.php?t=48020
http://www.dvinfo.net/conf/showthread.php?t=47434
http://www.dvinfo.net/conf/showthread.php?t=45114
http://www.dvinfo.net/conf/showthread.php?t=40368
Old August 16th, 2005, 10:15 AM   #3
Fundamentally, you need more light to create the additional information recorded in an HD image... so all things created equal, HD cameras will always perform worse.
Of course, all things aren't created equal.
-Steve
Steven White is offline   Reply With Quote
Old August 16th, 2005, 10:23 AM   #4
Certain types of uncontrollable situations not withstanding, if HD forces its new adopters to take a more serious approach to proper lighting, then I think that's a *good* thing.
Old August 17th, 2005, 01:41 AM   #5
-Steve
Steve, thank you, that makes a lot of sense, even to a nooby like me.. Thanks for the universal touch. :)
However when making comparason in the usability of Gain, then it gets clear for HD.
I think FX1, might be the better option for me over DVX100 then..
Thanks for the link Boyd, cheers
Old August 17th, 2005, 11:24 AM   #6
One thing one has to remember is that as technology progresses, so does the quality of the CCD and CMOS devices through which the latest cameras capture their images.
Whereas the FX1 and Z1 (and other) HD cameras do have a higher lux rating than their earlier DV counterparts and do require a higher level of ambient lighting, the introduction of lower levels of gain does not adversely affect the captured images, making the later generation of HD cams better options when taking their other features and quality into consideration.
In a test i did a few months back with the FX1 and PD170, I found that the FX1 performed better for me than the PD170 in the lowlight situations I sometimes find myself in.
Cheers
MJ Productions
Never let the need for money outweigh the need for Quality, Friendly and Professional Service
Jeremy Rochefort is offline   Reply With Quote
Old August 17th, 2005, 11:46 AM   #7
Barry Wan Kenobi
That may be true for the FX1/Z1, but you can't yet lump all next-gen HD cameras into the same basket, because the JVC HD100 appears to be just as noisy under gain as the current 3-CCD standard-def cameras.
The FX1/Z1 are exceptionally clean in gain.
Old August 17th, 2005, 12:16 PM   #8
Being an ardent loyalist, I was referring to the FX1/Z1 - lol. I can't comment on the JVC but it would seem I made the mother of all f$%k-ups - I assumed the JVC would fall into the same equation - ah well - as Steven has said
Cheers
MJ Productions
Old September 19th, 2005, 10:37 AM   #9
I like the results I have recieved from my FX1 in lowlight just like Barry Green said.. Nothing like my GL2 at all. And as Chris Hurd said, good lighting is key. Unless your situation doesn't allow you that. Even then, these cameras look good.
My 2 cents,
Sean
Sean Hansen is offline   Reply With Quote
Old September 21st, 2005, 01:49 AM   #10
All things equal, the progressive image will have a harder time with low light.
Damnit Jim, I'm a film maker not a sysytems tech.
Ken Hodson is offline   Reply
