February 24th, 2010, 06:45 PM | #1 |
hardware for HD xdcam 1920x1080
Hi hello, sorry for my poor english, i speak like the indians
I`l gona edit xdcam footage 1920x1080, In my computer. Mother: p5vd2 asus pentium 4 cpu 2.20g 2gb ram Ge force 9500 the problem: I cant run premier in this system. the cuestion: I need change both, mother and proccesor. or only change the procesor is good. Whith this mother (775 socket), the most powerfull processor is the intel core2 cuad its good? Another thing, avid vs premier cs4? wich is the best please help me. and good dreams |
March 7th, 2010, 05:01 AM | #2 |
I guess that depends on what are you planing to do with the material. Just for simple cut-cut editing I think maybe it would be enough, but anything else - I doubt your computer is gonna cut it. A quad core and more ram would help a lot. At home I use a dual core, 2gigs of ram, 3 disks and a firegl V8600 and if I want to edit smoothly HD mpeg2 or mpeg4 material I usually re-encode the material to an Iframe codec or just simply uncompress - depends on what I'm doing. But for work with uncompressed material you are gonna need some faster disk (raid 0 maybe, SSDs). I would recommend that you try this setup and then build it up step by step - seeing along the road what is it that you really need. But more ram and a faster cpu in my opinion is a must. And what about disks, what kind of a disk setup do you have? Doing it all on a one disk - with the OS installed on it - is a big no no to!
As far as the NLE editor goes - use the one you are more acquainted with. I use Avid MediaComposer just for editing. |
