noob question: HD on standard DVD
If I have a standard DVD, and I record in 720P, without shrinking the resolution or reducing quality how many minutes can I record onto a standard DVD?
I'm seriously considering getting a HMC150 and since it only records in HD, I want to know how many minutes I can fit onto standard DVD...or a dual layer DVD. I'm going to be recording lots of action/motion events and nearly all of the client(s) don't have BluRay. |
#2 | |
Now, if you're talking about placing video files onto a DATA DVD OR authoring an HD-DVD or Blu-Ray compliant video stream to be played back on an HD-DVD or Blu-Ray player onto a standard DVD, you're still going to compress the images. And your clients will require an HD-DVD or Blu-Ray player. If I understand your question correctly, you want to display HD material, recorded to a DVD, playable on a DVD player. This can't be done.
Shaun C. Roemich Road Dog Media - Vancouver, BC - Videographer - Webcaster www.roaddogmedia.ca Blog: http://roaddogmedia.wordpress.com/ |
what about if they use an upconvert DVD player and their TV say supports 720p?
You still lose resolution, it won't be true HD.
What you're thinking of is AVCHD. But that can't be played using standard DVD players, only Blu-ray players, And it's 1080i only. |
#5 |
An upconverting DVD player plays SD DVDs but does the scaling to HD at the DVD player rather than the TV looking after the scaling. USUALLY this is to accommodate HDMI connectivity to the TV or HDMI switching through an HDMI compatible video switching receiver. This may or may not provide better SD to HD scaling than the TV is capable of, depending on the quality of the converters both in the DVD player and the TV.
