Why not single chip ?
Could someone with the technical background please explain to me why top-of-the-line digital SLRs can shoot 10 megapixel or larger photos with excellent color at frame rates of up to 9 FPS using single chip blocks, while $10,000 HD camcorders can't shoot 1900x1200 at 60 FPS without three chips ? I realize that the RED and SI-2K cameras use single chip technology, but why haven't the major camcorder producers jumped on board yet ?
#2 | |
You can get small cameras with single chips - but they are inherently less sensitive than those with three chips of the same size (all else equal). |
I have heard it is a factor of heat as well.
The DSLR chips generate a lot of heat and in a constant video type application would not be easy to cool. Please correct if I am wrong. |
Convergence!
We may see 24fps DSLR offerings from major manufacturers in the next few years.
software engineer |
#5 |
Another factor is shutter speeds. While sometimes you may compensate for low light conditions by setting shutter speed fairly low on a still camera, it usually just wouldn't be practical with a video camera.
#6 |
#7 |
DVi Contributor
and both have problems dealing with the heat.
#8 |
I wonder if the forthcoming UHD cameras will be single or three chip?
Probably a very advanced single to follow the Red groundwork.
Panasonic HMC150/Canon A1/JVC HD1/Sony Vegas 8.0c |
