Blackmagic Intensity card and 24f footage?
Looking for a way to monitor my HDV footage for color-grading in post. I'm thinking about picking up the Blackmagic Intensity card for this purpose but don't see anything in the literature that says it'll support 1080p. I shoot with XH-A1s primarily in 24f mode.
Will the Blackmagic Intensity card have any problems outputting this to external monitor? Thanks in advance! |
Bump, to see if anyone might know. Thanks.
Did you find out yet?
Glen,
I have a black magic card on the way and was wondering if you were using one to view the 24f footage externally? Thanks |
Yeah, I took a chance and picked it up. Unfortunately it seems no one on here knew the answer to my question. Thankfully it does indeed work. It doesn't have a 24f/p preset but it still sends the signal. Im using a 40" Samsung T-series 1080p LCD to proof my colors, i love it! I calibrated it using blue gel THX glasses.
#5 |
Hi Glen,
Sorry I didn't catch this thread in time. Intensity does not actually support 24p. What it is doing is applying pulldown to the output to your TV so that you're monitoring 1080i59.94 in real time.
Blackmagic Design |
#6 |
Hey Kristian, thanks for chiming in. I don't know that 24"f" footage really even needs "pull-down" per say. Any insight into that? Granted the most important thing is that it works, which I'm grateful. I just wish I knew more about the ins and outs of both the footage format and how the hardware works.
#7 |
Glen,
I'm no expert, but I think that you're part right, the 24f doesn't need pulldown to play properly on your computer, but it must be put back into a 29.97 stream to play out of the card to your monitor. This a limitation of the card, and not your monitor or the camera itself. I don't think you'll know the difference watching it on your external monitor. It should "look" 24p to you. Any official Blackmagic people wanna chime in and correct me... feel free. I'm a hack. ***EDIT*** Looks like it's a 59.94 stream... but you get the point.
∅ -Ethan Cooper |
#8 |
Hi Glen,
Just came across this thread, and am curious about the cards myself. I am wanting to run the same setup as you (minus the very cool 40" lcd screen!), XHA1 in 24f, with the Intensity card. What NLE are you running it all on? (We have Adobe CS2 at the moment.) Thanks, --JA www.madjavaproductions.com |
#9 |
I have the Intensity card, and captured from an HV20 set to 24P. I then did a 3:2 pulldown using After Effects, and the video looks amazing on playback.
My problem is that it is out of sync in Premiere CS3 (project is set to 24P), but the video is in sync when played back in windows media player. Any thoughts? -S
When you get to the end of your rope, you either hang or hang on. |
#10 | |
Blackmagic Design |
#11 | |
Blackmagic Design |
#12 |
I am not trying to monitor through the Intensity card.
I am simply watching the video on my computer screen and the audio is out of sync with the video, when played back in Premiere. Yes, the audio does come out of the blackmagic multibridge, which I have on my editing system. Capturing is on a different computer. Again, it's in sync with this hardware configuration, when viewed with windows media player. -Sterling
#13 | |
So are you saying that the pulldown is being added by the Intensity card and not by the camcorder? I have an HV-20 and thought that the camcorder added the pulldown to 24P going out of the HDMI port. Are there plans for a laptop compatible version of Intensity? Thanks much! |
#14 |
I was planning to get this card for monitoring HDV and XDCAM footage. For those that have used it, can you use any timeline codec, for instance can I edit XDCAM EX in its native codec and just let the BM card send a component or HDMI output or do you have to use some BM specific codec?
Thanks, BE |
#15 |
any update on this?
I am using this setup with FCP 6.0.2 and I can't get it to output to the Intensity card. There is a signal going out because when I switch the card to something like NTSC DV out, it sends a crappy signal to the monitor that doesn't update in real time. So the connection is there. I got it to work once, but FCP was having problems at that point that required a fresh install and a firmware update to the video card. Since then, no luck. What settings are you using? |
