DR-HD100 various topics - Page 3 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old September 18th, 2006, 02:39 PM   #31
Focus Enhancements
The DR-HD100 ships with a cradle that features a 1/4" threaded insert which would allow you to mount to the IDX bracket.
Matt
Matt McEwen is offline   Reply With Quote
Old September 30th, 2006, 08:08 PM   #32
DR-HD100, re: assigning clips to reels
for Mr. McEwen -
I have thusfar been unable to successfully assign clips to specific reels in spite of a close reading of the manual (p.81)
When I mount the HD100 to my computer my recorded clips show up in an unnumbered folder separate from the default numbered ones. This occurs even though I can confirm on the LCD screen that the specified target reel is showing on the line above the FA function reel selection. This reel selection is made while the camera is in record, as per the manual.
Could you give me the proper protocol to make this handy feature work?
Mark Sanford
cam: JVC GY-HD100u
Mark Sanford is offline   Reply With Quote
Old October 2nd, 2006, 02:25 PM   #33
Focus Enhancements
From what you describe, it sounds like you have not done the Organize Reel step (from the Utilities menu) prior to connecting to a computer. This actually takes you Reel markings and physically moves the clip to a folder.
Hope that helps,
Matt
Old October 2nd, 2006, 03:55 PM   #34
[QUOTE=Matt McEwen]..it sounds like you have not done the Organize Reel step (from the Utilities menu) prior to connecting to a computer.
Matt -
Ahhh, yes, right there on page 82, plain as day.
Thanks for your help and prompt response.
-Mark
Old October 31st, 2006, 03:50 PM   #35
Timcode w/ dr-hd100
I'm having trouble getting my hd100 to send time code to the dr-hd100. I have the setting at TC Ext. on the dr-hd100 and TC Rec. on the hd100. When I record, the clips on the dr-hd100 start from zero while the clips on the hd100 are different. I'm either doing something wrong or it isn't possible. Any ideas?
Thanks.
Bill Parker
www.hindsightmedia.net
Bill Parker is offline   Reply With Quote
Old October 31st, 2006, 06:41 PM   #36
Focus Enhancements
You need to press the DISP button which displays all of the different TC modes. Using the middle Function key on the DR-HD100 (top row, under DISP on the LCD), press the key until you see either TC 720p/XX or DV NTSC. This will display source TC.
Matt
Old October 31st, 2006, 07:20 PM   #37
Trouble getting my DR-HD100 to act as AV/C Device for FCP Capture
Hi Matt,
I've been trying to get Final Cut Studio to recognize my Firestore DR-HD100 as an av/c device so that I can capture my 720 24p m2ts into native QT HDV, but I'm having problems. Final Cut does not recognize my Firestore at all when I have it connected.
Can you tell me all the settings I need to have in place for Final Cut to recognize my Firestore for capture?
Geoff Murillo
Geoff Murillo is offline   Reply With Quote
Old October 31st, 2006, 07:44 PM   #38
Thanks. I'll give it a shot.
Bill Parker
Old October 31st, 2006, 08:49 PM   #39
I just tried it as you suggested and the tc did follow although when I took it into FCP (via MPEG Streamclip), I lost it again (it started from zero). I've ordered the Quicktime HDV upgrade and I'm assuming that that will fix the problem, no? When it converts it to QT in the DR-HD100, I'm hoping it will include the tc information. Is that right?
Thanks.
Bill Parker
Old November 1st, 2006, 01:01 PM   #40
Focus Enhancements
Yes, the QuickTime HDV (version 2.0) support does do a re-stripe of the TC so that it will match. I believe that MPEG Streamclip ignores the TC in the conversion, but I cannot be 100% sure. It has been a while since I have used it. But, you should be good to go with the 2.0 version.
Hope that helps,
Matt
Old November 1st, 2006, 01:12 PM   #41
Thanks. I'll know in a few days.
Bill Parker
Old November 1st, 2006, 06:22 PM   #42
Focus Enhancements
Hi Geoff,
This is an known issue with FCP 5.1.2. I am happy to add you to the beta list for QuickTime HDV 720p24 support when it is available.
Matt
Old November 1st, 2006, 06:26 PM   #43
Thanks Matt. I would love to Beta test when the QuickTime HDV 720p24 support becomes available.
-Geoff
Old November 1st, 2006, 06:48 PM   #44
Matt, any chance I can get on that list?
Steve Benner is offline   Reply With Quote
Old November 1st, 2006, 07:01 PM   #45
Focus Enhancements
Sure, shoot me a PM with your email and other details.
Matt
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
