FS4 / FS4 Pro HD various topics - Page 13 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old February 25th, 2006, 09:55 AM   #181
Hi Daniel,
Do you have any followup regarding the tc issues and fcp?
Thanks.
Ken
Ken Castellano is offline   Reply With Quote
Old March 5th, 2006, 07:31 AM   #182
Quirky Behavior w/ FS-4 HD
When I imported some m2t clips into my NLE (Vegas), I noticed two of the clips appeared to be longer in length (double in length on timeline) athough the file size was typical (bytes). The two clips in question had solid color frames in the area of extra length and no audio. Anyone seen this?
Mark A. Foley is offline   Reply With Quote
Old March 6th, 2006, 01:51 PM   #183
My bad...was problem with vegas...
Old March 7th, 2006, 12:19 AM   #184
FS-4 Will Not Mount!
I have an FS-4 and used it to test record a few minutes of footage. I tried to mount it on my PowerMac G5 but wouldn't mount. Then I tried on my PowerBook, and still the same problem. I have no idea what's going on.
Any help??????
Vishad Dewan is offline   Reply With Quote
Old March 7th, 2006, 07:54 AM   #185
Could be due to the way the FireStore was formatted. Is it NTFS or FAT32?
Old March 9th, 2006, 11:58 PM   #186
Chris: Its FAT32 from the factory....Don't know if it would be possible to have windows format it as NTFS, although it might be worth a try!
Vishad: I don't know jack about a G5 but I'll ask the same thing I have to ask myself every time I plug the FS-4 into my PC.....Are you in the computer plug or the DV plug?
My computer reads the unit like a DV camera if I am in the DV plug so I get the audio confirming a new connection but then find myself going "Where is IT?!?!" until I realize I did not swap the cable on the FS-4 to the computer connection.
Sorry for asking such a basic question but I have found, especially in trouble shooting PC problems, that it is usually a simple thing that slips by and messes the whole ball of string up.
Randy
Randall Allen is offline   Reply With Quote
Old March 10th, 2006, 11:36 AM   #187
Any help??????
Vishad,
This is a repeat from another post, but it may help you. You did not specifically say if the footage was not available or it just is not recognized, but since you said "mount," I will assume that the computer will not see the
fs-4.
This may sound silly, but the first time I used mine I failed to move the firewire to the computer port from the camera port.
Then, (and they put this where it is hard to find on the page before the hook up page, and don't explain it at all!!) you have to go into HDD mode, go to DD and press select.
This brings up the connect screen and tells you to "CONNECT," to the computer and then press "ENABLE." It will connect then just fine. When removing it, be sure to follow the directions there about exiting etc.
Hope that this helps, and if not let me know. A very poorly written manual in my IMHO.
If you need further assistance, please let me know.
Mike
Mike Teutsch is online now Reply With Quote
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old April 10th, 2006, 07:52 AM   #188
Firestore will not mount to G5!
We are experiencing real problems connecting our firestore fs4 to our Mac - we go through the proper process, but it often comes up with the message 'failed', or the firestore restarts, or just nothing - what are the possible issues? The cables seem to be fine, we cycle through to the correct screen (HDD then DD drive then enable) but now more often than not - nothing!
Any help would be greatly appreciated!
Graeme Moodie
Graeme Moodie is offline   Reply With Quote
Old May 11th, 2006, 06:27 AM   #189
Firestore FS-4 pro
OK, been reading alot, but what's the real RELIABILITY of this drive? I'm planning on running it 20hrs per week. Any of you using it regularly? Any problems?
Eric Pontbriand is offline   Reply With Quote
Old May 11th, 2006, 06:43 AM   #190
Moved here from Open DV Discussion.
Old May 23rd, 2006, 03:19 PM   #191
FS-4 conection to computer problem.
Hi, I just got the FS-4 to go with my Canon XL-1s. Records and plays back great...on the camera. However, the supplied 6 pin-4 pin cable does not work with my HP. Is there another cable I can buy? Can I get a 6 pin-6 pin? Or, a 6 pin-usb? My 3 year old HP does not have a 4 pin dock. Bob
Old May 23rd, 2006, 03:24 PM   #192
Focus Enhancements
Hi Bob,
We do sell 6-pin to 6-pin cables on our westore and through our dealer channel, but it is probably better to just go and buy one from a computer store. Any 6-6 pin cable (within 1394 spec) should work.
Hope that helps,
Matt
Matt McEwen is offline   Reply With Quote
Old May 23rd, 2006, 03:57 PM   #193
Matt, thank you for the quick reply. I am off to the store right now. Thanks again. Bob
Old June 15th, 2006, 08:11 PM   #194
FS4 LCD quality
i wanted to ask this for a while. The LCD on my FS-4 looks lousy. Kind of like smears going down
anyone else having this. Kind of annoying to have to send it in just for that but ...
Michael Salzlechner
Michael Salzlechner is offline   Reply With Quote
Old June 16th, 2006, 11:04 AM   #195
Focus Enhancements
Hi Michael,
Have you tried adjusting the contrast on the LCD (last setting in the SETUP menu)?
Matt
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
