Need some help hd100 & fs4prohd 80 gig
Hi guys,
run a few tests on my fs4 pro and in hdv mode sync slave its chopping my scenes into more than one clip. e.g I need 6 takes but enede up with 20 files? all of the clips were way under the 9gb threshhold. the way it chops the scenes is sporadic also. I called focus and they said it may be a setting on the camera I have the hd100 set at hdv 720p 24fps. Anyone got any ideas because I'm stumped. Thanks Greg C P.S. both firewire ports seem to be working ok e.g. the camera connects to my computer no problem and the firestore connects to my computer no problem. Last edited by Greg Corke; February 17th, 2006 at 09:30 AM. Reason: adding stuff |
Contributor
Are there any lost frames between the files?
If not - is it possible that the REC button on the FS-4 is getting hit while shooting. This may cause the FS-4 to create a new file without interrupting recording - at least it does in DIRECT mode. (I know this is an unlikely cause, but it's the first thing that came to mind) |
Hi Daniel,
Thanks but unfortunately I know what you mean but it is not that. It happens randomly about 5 sometimes 6 seconds into a clip. I have a work around by just manualy hitting record, not ideal but usable. I need it for Monday and there is no way I'm going to get it turned around that quick but at least I have that back up that i need and I'll send it back to focus once I've finished my project. Thanks again. Greg C |
I was under the impression that the Firestore was not out yet for the HD100. Am I mistaken?
#5 |
dr hd100
Hi Heath,
I think your are refering to the jvc dr hd100 it's a firestore with jvc badge you are correct they are still testing it but the fs4prohd 80gig is almost identical with regard to features. Hope this helps Greg C |
#6 | |
Contributor
#7 |
Greg.
Is this device having any problems with time code? I read a post by Shannon that the FS-4 HD he had was having a lot of problems with time code in HDV. |
#8 |
Not sure if it's time code I'll keep you guys posted on what Focus find. And John the 9gb was supposed to be 9 minutes, sorry.
Regards Greg C |
#9 |
Happening here too. We are getting our longer records split up into equal 9min+ segments. Sadly, in Raw DV format, when importing into Avid, each clip, even though they are sequential begins with a TC of 00:00:00:00. Now that sucks.
Calls into Focus Enhancements on this one. More concerned about the TC issue than the split files. Sean Mchenry
‘I don’t know what I’m doing, and I’m shooting on D.V.’ - my hero - David Lynch http://www.DeepBlueEdit.com |
