HD upgrade fitted and working at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old November 20th, 2005, 02:31 AM   #1
The upgrade adds a new category 'HD recording' to the 'HDD Mode' screen and a new HDD recording screen.
Only tried it briefly but all seems to work fine. I recorded a few minutes from the Z1 to the FS4 then played it back through the Z1, also checked the m2t file when transferred to computer.
The revised manual on the CD (pdf format) simply says
"Support for cutting edge HDV camcorders with 720p and 1080i capacity equipped with a Firewire 1394 connection"
What it DOES mean is that the continuous recording limit of one hour (set by the physical size of HDV recording tape) is extended to almost three hours - of particular interest to event videographers.
Ray Liffen
Ray Liffen is offline   Reply With Quote
Old November 21st, 2005, 10:25 AM   #2
Z1/FS4 anomalies
Ray,
Glad to hear things are working so far. I also have the upgrade and I use it with an HD100 and a Z1. I've noticed that my Z1 files are fine if I'm just recording with the FS4 (not recording to tape). However, whenever I record with tape (syncro slave or just 'Local'), some of my files tend to get corrupted, and they play back very erratically in my editor. I use a Canopus Edius 3 system. Vegas won't even load some of the files, Edius tries to work with them and gets very sluggish or freezes.
I can't help but think it's a bug (not the editor), as I've seen Z1 files play fine, only not when recording with the tape. Perhaps some funky timecode/sync issue? This has been consistent with 2 FS4 units, and I've never seen it happen when recording with other cameras in DV mode. I thought the HD100 was fine as well. Maybe it's my camera, but I don't know why that would be either...
Any advice or testing would be greatly appreciated. I was trying to work it with Focus support, but haven't heard back in a while.
Shawn
Just curious what you find - if you can test recording to tape as well (synchro slave, and on 'local' mode hitting the Z1 record button on/off as the FS4 continues to keep recording).
Shawn Alyasiri is offline   Reply With Quote
Old November 22nd, 2005, 12:38 AM   #3
Shawn
I'm snowed under with work at present (everyone wants their job edited and finished in time for Christmas) but I'll investigate further as soon as I can.
Ray
Old December 19th, 2005, 07:25 PM   #4
Originally Posted by Shawn Alyasiri
Ray,
Can you explain how you get the Z1 to work tapeless? I'm missing something here.
Jim Harvey is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
