FS-4 Syncing at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old December 7th, 2010, 04:29 PM   #1
FS-4 Syncing
Hi all, I did a search and couldn't find a definite answer...
I borrowed an FS-4 (HD) to use over the weekend with my Canon XH-A1. I've used FS-4's in the past with no problems (with other cameras), but in trying to set it up this morning I could not get the device to sync or record in either mode; manual or sync. I have DV Control set to "on" in my camera, is there anything else I can try? I know both Firewire cables I tried are good, and I have tried in both HD and SD modes (I am only using SD this weekend). I will list the steps I am taking below. Thanks in advance.
1. Plug in Firewire to camera and DV port on FS-4.
2. Power on camera.
3. Power on FS-4.
4. Choose Sync.
5. Press record on camera.
OR
Hit "record" on FS-4 twice, then roll tape on the camera. Either way, it does not yield a rolling timecode on the FS-4.
Mike Flynn is offline   Reply With Quote
Old July 10th, 2011, 12:05 PM   #2
Re: FS-4 Syncing
Mike, did you ever resolve this problem? I am looking at buying a second hand FS4 for use with my A1S and it would be nice to know whether it is going to work or not!
Cheers,
Ian . . .
Ian Stark is offline   Reply With Quote
Old July 10th, 2011, 12:34 PM   #3
Re: FS-4 Syncing
If the FS-4 is the same as the FS-CF...
Did you turn on the XH-A1 DV Control (System Setup Menu, page 74) function in the menu to control the FS-4 from the camera record switch?
Ed Roo is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
