DVX100A 12 bit - Firestore 8bit ? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old July 16th, 2005, 10:06 AM   #1
The fs-4 specs read:
Audio/Video/Timecode Specification
25Mb/s, 8-bit 4:1:1 (NTSC-DV) or 4:2:0 (PAL-DV) video (model dependent)
DV Embedded Timecode (Drop or Non-Drop)
Embedded 2-ch (16-bit, 48kHz) or 4-ch (12-bit, 32kHz) Audio
Doesn't the dvx100a record using 12bit processing?
Are these specs referring to different things?
-josh
Joshua B. Backer is offline   Reply With Quote
Old July 16th, 2005, 01:47 PM   #2
Barry Wan Kenobi
Different things. The internal DSP of the DVX is 12-bit, but the recorded DV format is all 8-bit. Every DV camera (from a $299 Circuit City handycam up to a $18,000 Sony DSR450) all record on tape in 8-bit. And that's what the FireStore records.
Old September 1st, 2005, 02:03 PM   #3
What method to downgrade 12-bit DSP video data rate to DV 8bit?
TIA
Leigh
Leigh Wanstead is offline   Reply With Quote
Old September 7th, 2005, 07:33 PM   #4
Contributor
What Barry is saying is that it is already done withing the DVX. It is not something you should worry about.
John Mitchell is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
