Just got a new H200 for XH A1s at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old February 27th, 2010, 02:42 AM   #1
Read posts for a couple weeks. First post. My H200 worked out of the box on external mode once I turned on my DV option on my Canon. So far everything is as it should be. I have the unit mounted to the handle using the included mount, and I don't particularly like this setup. Does anyone have any suggestions for a more convenient mounting for this? I an pretty handy and will experiment, but wanted to ask if anyone has found a better setup.
Kevin Kruger is offline   Reply With Quote
Old February 27th, 2010, 04:51 AM   #2
OK I found the post with the mount options. Sorry about the q. I am curious as to what would be your thoughts on the disadvantages of a tripod mount and a belt clip when going mobile. Thoughts?
Old March 3rd, 2010, 08:08 PM   #3
Pro upgrade
If you end upgrading to the fsh200 pro, watch out if you are using cheap CF like kingston 133x they will work in the fsh200 but not after the upgrade! I stuck with the handle mount!
Mestizo Devon is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
