Recording with FS-4 Pro HD at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old October 21st, 2009, 07:25 AM   #1
HI,
I just did my first job with Canon XL-H1 and FS-4 HD Pro, Sync, tape and FS-4, however I now downloaded all files to my computer and thee are around 350 clips. When I try to import them to Premiere 4 about 10% of files give me error and I can not import them to the Premiere, it says they are damaged or not usable, why is that?
Any help in much appreciated.
Regards
Mitchell
Mitchell Yazdani is offline   Reply With Quote
Old October 27th, 2009, 10:56 AM   #2
Hi Mitchell,
I have the same Probelm. Hope some wone can help us.
Freddie
Freddie Hoekerd is offline   Reply With Quote
Old December 2nd, 2009, 05:02 AM   #3
Is any one from Focus here at all?
We realy appreciate some sort of help.
Old February 8th, 2010, 11:42 AM   #4
Im on a MAC and it works fine for me in Final Cut.
Canon 7D and 5D Mark II,Canon XL H1, XL2, Cinevate Atlas 30, Advanta Jib, AJA i/O, KONA LHe, AJA I/O HD, ZEISS PRIMES, G5 Quad Core, MacPro 2.66GHz, XSERVE RAID 10TB
Gregory Dillard is offline   Reply With Quote
Old February 9th, 2010, 01:04 PM   #5
Mitchell, what format did you use? Also what error does it says?
Not sure with that DTE model but with the FS-CV, Quicktime files does not work on PC, only on Macs. On PC I only use Canopus for standard and M2T for HD whithout any problem. You may want to try to open it with another player like VLC Player and see if it opens ok there. If it does convert them into another format friendly to Premiere.
Hope you find a solution pronto,
Alex
Alexis Vazquez is offline   Reply With Quote
Old March 28th, 2010, 06:12 AM   #6
That's odd, I've been using one of my FS-4 HDs with my XL H1 for nearly a month now without any problems with the M2T format and importing them into Premiere CS4/After Effects CS4 without any issues.
Motion Blur Studios - Canon XL H1, XL2, nanoFlash, 2xFS-4 HDs, Custom 9TB RAID 10 Array HPT RocketRaid 4320, GeForce GTX 480, Adobe CS5 Production Suite
Jarred Capellman is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
