FS-4 DTE Recorder Test Results - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old February 27th, 2005, 03:47 AM   #16
Contributor
Hi Phil,
Both modes of operation are possible.
In SYNCRO/SLAVE mode the tape and FS-4 are controlled by the camera's start/stop button- thus synchronized.
Or you can shoot with the FS-4 in LOCAL mode, which means the FS-4 runs independently from the camera's tape system. That means that you will have to push start/stop on the camera to start recording and then the record key on the FS-4 to start recording.
The FS-4 will most likely be able to read the time-code being written to tape by the camera regardless of wether the FS-4 is in SYNC/SLAVE mode or LOCAL mode. Making it easy to match taped material with captured material in both modes.
In other words, this shouldn't be a problem for you.
Daniel Kohl
Frankenstein meets XL1
Daniel Kohl is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
