Lacie 160GIG at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old March 16th, 2004, 09:46 AM   #1
Lacie 160GIG
I have formatted and partitioned my 160 GIG drive into 5- 30 GIG Drives with FAT32.
Is there another way to get more on the Fat 32 formatting?
Also the FS-1 does not read the drive if it has more than one partition.
I have 40 GIG Fat32 drives that came with our FS-3 and those work well. It says on the website that you can also order an 80 GIG drive.
K
Kevin Willman is offline   Reply With Quote
Old March 18th, 2004, 10:58 PM   #2
Focus Enhancements
Hi Kevin,
Thanks for your post. I encourage you to contact our tech support department as there has been some issues with certain Lacie drives which we have a solution for. Having said that though, I am not sure if our test department has qualified this drive...but check with tech support.
You are also correct, the FireStore FSHDD-1 FireWire drives are available from Focus in both 40GB and 80GB versions.
Hope that helps,
Matt McEwen
Matt McEwen is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
