Various Firestore questions - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old July 20th, 2005, 07:53 PM   #16
How to upgrade FS4 from 40GB to 80GB ?
I have opened the case and find the connection is very delicate and my question is what is the proper way to remove the connector (tools or hand)?
Frank Dago is offline   Reply With Quote
Old July 21st, 2005, 08:40 PM   #17
FS4 Noisy Fan
Is it ok to unplug the fan ? As it is way too loud even after FWare upgrade.
Old July 26th, 2005, 07:09 PM   #18
Clear/Soft Protective Plastic on FS-4
Does anyone know where I can get some of the clear/soft plastic protective sheeting that come on the Firestore from the factory? Like to keep the face in good shape as much as possible while being handled in the field
Mark A. Foley is offline   Reply With Quote
Old August 4th, 2005, 02:20 PM   #19
Mounting the FS-4 on a camcorder
For early adopters, here's a way that costs UK £8.99 (about US$14?).
Early adopters got the FS-4 holster as part of the package. The holster is threaded to take a tripod screw.
Buy the Hama Shoe Mount (£8.99 from Keene www.keene.co.uk ) which takes you from tripod threaded screw to camcorder hot shoe. The Shoe Mount has two knurled locking nuts so the Mount can be locked to the holster and then to the camera once clipped into the hot shoe.
Used directly, the FS-4 will lie flat, and parallel to the camera body, but I generally use an L-bracket so the FS-4 will stand vertically (easier to check the blue screen)
Ray Liffen
Ray Liffen is offline   Reply With Quote
Old August 22nd, 2005, 02:52 PM   #20
TC with FS-4?
I have looked a few places in my manual and online and not sure if I am able to capture the TC when I use my FS-4 and my TRV900 camera. Is this possible or is time code only available with the Pro FS-4's?
Rick Sutter is offline   Reply With Quote
Old September 1st, 2005, 09:44 PM   #21
Inconsistent start up
Yesterday was my biggest shoot with the FS-4 so far after several shorter shoots. I use it with an XL1s and roll tape as a backup.
There are two issues concerning me. The first is sometimes the unit doesn't power up, causing a significant delay while everyone waits for me to try again. I don't know whether it is me holding the button down for too long (or not long enough), or my unit has an intermittent fault.
Secondly, when it does power up, sometimes it is in the right mode (synchro slave) and ready to go, in which case the cam VF indicates [STOP] mode. Other times, the camera indicates the FS-4 isn't ready and when I go through the menu on the FS-4 it is back on local mode.
I always power up the cam first as recommended so I don't know why this happens. It causes many annoying delays and also I end up recording shots on tape that don't make it onto FS-4.
Yesterday I was waiting for chickens to hatch and missed the "money shot" due to this.
The other major issue (I'm sorry, this makes 3) is the battery life. I wouldn't be so worried about power up/down problems if the battery would last. I know a longer life battery is now available but for those of us who have the holder mounted to our cameras, this holder won't accommodate the bigger battery.
May I suggest that a bigger holder be made and supplied with the bigger battery when purchased by those of us who bought the field kit?
MW
Mark Whittle is offline   Reply With Quote
Old September 25th, 2005, 11:03 AM   #22
FS-4 24p PROBLEM please help
I use my FS-4 (not pro) with an XL2, and edit in FCP 4.5. When I record to 'Quicktime 24p' roughly the last 10 seconds of video becomes corrupt or something. They play back as a checkerboard of many different colors. The audio still plays through, it's just the video that's messed.
Anyone else experience this? Any known fixes?
Chris
Chris Frisella is offline   Reply With Quote
Old September 28th, 2005, 02:45 PM   #23
FS-4 some problems
There's a strange bug in my FS-4. The charge light is always on when a battery is attached. It shines in orange-red and the only way to stop the led is to remove the battery.
Looking at the battery and battery connectors on the FS-4 I see that there are 4 metal connection parts on the battery but only three connectors sticking out on my FS-4. Can anyone check for me how it looks on there unit?
And are people having problem with the FS-4 running hot quickly when attached with firewire to a Mac?
TIA
Erwin.
Erwin van Doorne is offline   Reply With Quote
Old October 9th, 2005, 11:49 PM   #24
FS-3 support
Most of the threads seem to be about the FS-4. I have the FS-3 and have been using it with the XL-2. Will I be able to upgrade the FS-3 for use with the
Canon HD-1?
David Mesloh is offline   Reply With Quote
Old October 20th, 2005, 01:08 PM   #25
GPI for FS-1
I need to pause a FS-1 with GPI. I need a cable with a push button. Any thoughts?
Doyle
Doyle Keeton is offline   Reply With Quote
Old November 4th, 2005, 12:56 PM   #26
FS-2E and FS-2 software update
Anyone heard what the release date is on this yet? Matt?
Bob Irwin is offline   Reply With Quote
Old November 8th, 2005, 03:34 PM   #27
Anyone used FS-4 HD upgrade yet?
Has anyone ordered and received their hd upgrade yet? We ordered one October 27 and still haven't received it. Email enquiries to Focus have bounced back.
Joe Moulins is offline   Reply With Quote
Old January 9th, 2006, 09:35 PM   #28
Underwater housing
Does anyone here have an Equinox Pro Pak 8 housing? If so would an FS-4 fit inside on the housing. I will have the rear mount LCD so the cameras LCD will be folded in.
Chris
Chris C. Corfield is offline   Reply With Quote
Old February 25th, 2006, 07:54 PM   #29
Sponsor: divergent media
Mounting FS4Pro on XL-H1?
So, I'm still waiting on my Firestores (Focus has shipped me the wrong products twice now ...), but I'm wondering how people are mounting the Firestore on their XL-H1. I know I can use the mount kit to put it in the hotshoe, but is it possible to secure it to the accessory holder as well?
Divergent Media Support
www.divergentmedia.com
Colin McFadden is offline   Reply With Quote
Old March 1st, 2006, 08:01 PM   #30
Firestore FS-3 problems
I have a FS-3 that I have been using with my Sony DSR-500 DVCam.
It has worked VERY well up until tonite, when I was packing for a shoot and doing an equipment test, My camera would flash the "warning" light when the FS-3 was attached and powered up, both with AC power or a battery.
If I took the FS-3 off and just powered the camera normally via the AC or battery everything looks fine.
Any ideas on how to resolve this?
Matt Gottshalk is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
