Fsc fire store won't record at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old December 10th, 2008, 11:01 AM   #1
i've got a fsc that i hook up to my xlh1 and xha1 cameras that has the following problems. when i try to record to it, it will not record at all if i hit record on the camera. if i push the record button on the fsc the screen flashes red and the status light turns red. when i hit record again the screen stays red as does the status light and the counter does not run. it will not record at all. it show rec in the screen and will pause as it should but does'nt record at all. any help? thanks
Rick Lovelace is offline   Reply With Quote
Old December 11th, 2008, 11:53 PM   #2
This is relevant to a different problem but some of the steps may help you sort out your problem:
STEPS
***DO NOT HAVE ANY CONNECTION VIA FIREWIRE TO THE CAMERA.
***JUST CONNECT THE FIREWIRE TO THE "DV I/O PORT" ONLY, ON THE FIRESTORE.
Before trying the steps, make sure that the unit is in complete stop mode. Meaning the "TOP LINE" on the Firestore does not have:
1) E STOP
2) Y REC
The unit "must" be in STOP mode before attempting
FIRESTORE
1) Power unit ON.
2) By the SELECT button, press the RIGHT arrow key until you see the "HDD MODE" menu.
3) Scroll down to the recording option you want.
4) Once the option you want is "highlighted", press the SELECT button to choose that option.
5) Press the "LEFT" arrow key. This will take you back to the top of the menu.
6) Now press the "RIGHT" arrow key. You will be on the "FORMATS" menu.
7) Scroll down to the recording option you want.
8) Once the option you want is "highlighted", press the SELECT button to choose that option.
9) Press the "LEFT" arrow key. This will take you back to the top of the menu.
10) Now press the "RIGHT" arrow key until you get to the "FUNCTIONS" menu.
11) Scroll down and "highlight" FA SYNC.
12) Press the "SELECT" button to choose this option.
13) Press the "LEFT" arrow key. This will take you back to the top of the menu.
14) Now press the "RIGHT" arrow key until you get to the "CONTROL" menu.
15) Scroll down and highlight "TAPELESS" or “SYNCRO SLAVE”.
16) Press the SELECT button. (The unit will go back to home-screen with this display: E STOP (tape less) or Y REC (syncro slave))
**FireStore is now SET UP.
CAMERA
1) Power Camera ON.
2) Press your Menu button.
3) Look for a icon that says "DV CONTROL".
4) Turn the DV CONTROL "ON".
5) EXIT the menu.
6) CONNECT the other end of the FIREWIRE to the CAMERA.
**Camera is now SET UP.
7) Press RECORD on your camera. The FireStore's time code should be running
Guy Shaddock is offline   Reply With Quote
Old February 8th, 2009, 03:39 PM   #3
Firestore Wont Record
Rick, I have the same issue that you had. Did you find out anymore information about this issue? Thank you.
Roger Willis is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
