Blue backlight is dead on FS-4 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old September 14th, 2008, 11:00 PM   #1
The blue backlight on my FS-4 no longer works.
FireStore charges $245 to fix this - they charge $245 to fix anything, so there is no way to determine if this is a major repair issue or a minor one.
It is an annoyance to not be able to read the display in dark situations, but I can put up with it.
Has anyone fixed it or heard of anyone fixing it without having to send it in?
David Yuen is offline   Reply With Quote
Old November 17th, 2008, 04:25 PM   #2
I have a DRHD100 with a cracked LCD. Works fine otherwise. It was the unfortunate victim of a backwards camera move. It's out of warranty.
I have taken it apart and the LCD panel comes out easily, but I have no idea where to get a new one. Any ideas for finding these parts? I would assume it's not a $250 part.
DB
Dave Beaty is offline   Reply With Quote
Old January 29th, 2009, 02:14 PM   #3
The LCD part is labeled M534-LOA or L0A it is approximately 70mm X 50mm
Can't find this # on Mouser, still looking
Very close to this display for $19
763-12864CZ-FSW-GBW
Mouser Part #: 763-12864CZ-FSW-GBW
Manufacturer Part #: NHD-LGC-12864CZ-FSW-GBW
Manufacturer: Newhaven Display
Description: Chip on Glass- Graphics 128 x 64 STN-GRAY 71.3 x 54.9 x 5.9
Not sure if anyone has any more info like voltage or interface type. That might help narrow it down. Also, this one doesn't say it uses a blue type crystal.
Old January 29th, 2009, 02:21 PM   #4
Thanks for the info!
Old February 3rd, 2009, 02:17 PM   #5
More info on this part
I removed the damaged LCD and both the serial connector and power for the backlight have easily removable connectors. On the cable of the LCD are these part numbers:
56219201T802
LDC75T534FDG
28 pin serial cable
So far no luck in tracking the right part down on line.
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
