Firewire Hub Suggestion at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old April 11th, 2008, 07:24 PM   #1
Hello,
Your help would be greatly appreciated. I connect a XH-A1 to a FS-4 HD during acquisition. I would like to split the DV signal and connect the XH-A1 to the FS-4 (for archiving and editing) and a PC (for live streaming over the internet).
My request is for suggestions from people who are doing of have done this (other threads seem to indicate so) and what brand/model of hub was used. I want to avoid bricking my FS-4 :)
BTW-I have a Firewire cable that has interchangeable connectors.
David Easterling is offline   Reply With Quote
Old April 11th, 2008, 09:03 PM   #2
You can probably achieve your goal with what you already have.
3-port FireWire interfaces can effectively act as hubs. If you can connect your equipment in the following way then it should work.
Camcorder------> Port #1 of PC FireWire ----> Streaming
Port #2 of PC FireWire ----> FireStore
i.e., the PC sits in the middle. Whatever is entering the FireWire interface is replicated on the other ports.
John Miller is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
