Ouch Now what ??? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old February 12th, 2008, 04:08 PM   #1
Ouch Now what ???
I know this has had to happen to someone here,
We where setting up to film a segment of our tv show and I thought the firestore cradle was attached and tight
well i thought wrong I pan down and you guessed it off she goes on to the cement floor!
It was off and i push power on and now all it does is power on and the fan runs no display and you have to take out the battery to turn off
I called Foucus enhancements today and to my shock it would cost a min of 250 dollars just to crack it open??? Its a fs 4 40 gig with miles on it , so it isnt even worth it to fix
anyone else have this happen and they fixed it themselves?
any other suggestions except scrapping it!
thanks
Kirk Graham is offline   Reply With Quote
Old February 12th, 2008, 06:25 PM   #2
If you have a hard drive laying around, you could try swapping it out, or check the current one. I have an IDE to USB adapter that converts 3.5" and 2.5" IDE drives to USB, you could check it with one of those (cheaper than a new drive if you don't need one.)
Edward Carlson is offline   Reply With Quote
Old February 12th, 2008, 10:47 PM   #3
i would open it, see whether anything is broke. Say the screen, or the HDD is killed. I like opening electronics but that does not mean you do. Next time if you get it fixed, I would strap that baby down like it was going on a hike or camping.
I would also swap the hdd like Edward suggested.
dcrin3.com
we don't know alot of genres, at least as of now.
Kalulu Ngilo is offline   Reply With Quote
Old February 13th, 2008, 07:58 AM   #4
open up!
I am going to open it up and take a look! what harm can it do its already broken
I will follow the nicely detailed instructions on the HDD swap that would be nice if the HDD is just bad i can them up grade it then
Thanks for the tips!
Old February 13th, 2008, 02:12 PM   #5
it works again, I took it apart and unplugged the Hdd and plugged it back in and it started back up ! I ran 5 min of video on it and it worked fine
Old February 14th, 2008, 10:48 PM   #6
thanks great news! Leave it on until the battery dies just to make sure its all cool.
while in rome, Anyone use a different battery than the one supplied by Focus E. to extend the battery life?
dcrin3.com
Old February 15th, 2008, 06:57 AM   #7
try:
Http://powerbagjunior.com
Joe Matyas is offline   Reply With Quote
Old February 15th, 2008, 07:19 PM   #8
Originally Posted by Joe Matyas View Post
thanks, is there anything cheaper that works like this one?
dcrin3.com
Old February 16th, 2008, 02:29 PM   #9
Someone had mentioned one of the Black & Decker power to go packs. It's about the same size as the Firestore and you'll need to plug the AC Adapter into it. If you're running and gunning, I suppose you could improvise a portable power solution using one of those and a fanny pack/hip pouch.
Bryan Houston is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
