Firestore upgrade unless I'm wrong 'Timelapse' at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old December 4th, 2007, 06:28 PM   #1
Great feature of the firestore I used for the first time yesterday, great potential, only problem is it works only in DV mode!
Maybe I'm wrong, the manual states the same, and I could have sworn I recorded in 16:9 PAL SD, but it came out 4:3?
So if any of the Firestore people keep an eye on this forumn, thanks for a great product, please make it even better by including hdv timelapse and the 50/60p support!
Regards
Adam
edit - ok so I'm reading other threads, they say you can't have timelapse hdv because of the GOP? Why not?
Adam Letch is offline   Reply With Quote
Old December 4th, 2007, 09:55 PM   #2
Hi Adam
Not sure which Firestore you are using? Im using FS-4HD. Cam V1P set to SD 16:9 and I test it. Direct playback from Firestore is 16:9 SCREEN. You should check your cam setting output iLink to Firestore
Edit on Adobe Creative Suite Production Premium CS5 Mac 64BIT
K.C. Luke is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
