Portable hard disk drive? - Page 3 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old August 11th, 2003, 03:06 PM   #31
Don,
-- “Why would you want to bypass recording to tape? Tape is cheap. In the here and now, you'll still want to record to tape at the same time when using any of these hard disk recorders, as the tape is now your master backup archive. Always have a backup! Not having a backup is simply not using good judgment, especially when you are charging for your services and you need to get it right the first time. And, if you are not currently archiving all of the footage you shoot, you should be!”--
Did not think of that! It sounds wise! However, I think it “might be” a toss up between extending camcorder life & the cost of using the HD's as archival media.
The more I think about it… Since it is a fairly new technology… Yes, it is wise to have both!
--"having the ability to re-purpose your footage is key."--
Why would one not be able to re-purpose with HD technology?
Can you expand on "re-purpose" from your point of reference, please.
Virginia Benedict is offline   Reply With Quote
Old August 14th, 2003, 12:16 AM   #32
Laird CapDIV
The Laird Capdiv system is really a nice solution. For around 1500.00 you can capture 4.5 hours of video. I have used it in tandem with tapes. That way I have a back-up and when it comes time to transfer the footage it is basically drag and drop. It comes with a 6 hr. battery. weighs about a pound and a half on your belt. If you count the amount of hours you spend in front of your computer capturing video to the computer, this thing saves you time which = money. Besides if we can afford the toys we currently have we can always increase VISA's profits this year by having more toys.........<grin>
David
David Mesloh is offline   Reply With Quote
Old August 14th, 2003, 06:25 AM   #33
The only concern I have is that, if my memory serves me correctly...
when capturing to a hard drive it is simultaneously compressing!?!?!?!
If so, I consider it a big drawback!!!
All compression algorithms loose characters, spaces and/or pixels.
Uncompressing does not return the original quality of the data, digital or not.
I wonder, if one can turn off the compression as an option!?!?!
Of course, then it becomes a footprint vs real estate issue.
Hence, until the protable hardrive technology evolves...
Old August 14th, 2003, 08:58 AM   #34
Moderator
Virginia,
The short answer is "no".
The video is already compressed 5:1 in-camera. By feeding the external firewire recording device an output of the firwire port from your camera, you are in essence capturing the same signal that is being recorded to tape.
To clarify, there is no analog-digital-analog media convertor in these units. They are simply being fed a DV stream from your camera's firewire port.
Here is a link to Focus Enhancement's FAQ .pdf's (bottom of the page, plus some streaming video.
http://www.focusinfo.com/products/fi.../firestore.htm
David, are you using the CapiDV system? That 6-hour battery weighs more than 1 pound, it's more like having a bag of sugar strapped around your waist.
- don
DONALD BERUBE - noisybrain. Productions, LLC
Director Of Photography/ Producer/ Consultant
http://noisybrain.com/donbio.html
CREATE and NETWORK with http://www.bosfcpug.org
and also http://fcpugnetwork.org
Don Berube is offline   Reply With Quote
Old August 14th, 2003, 09:52 AM   #35
battery
Yes the battery weighs more than a pound, however the unit by itself is about 1.3 pounds . I use a power belt for my camera anyway so I usually can't go swimming while I shoot.
Old September 21st, 2003, 01:48 PM   #36
Moderator
FREE Focus Enhancements FIRESTORE DTE© Seminars beginning September 23 around the US
Hello all,
In case you would like to get a chance to see the new Focus FireStore products *in person* - FOCUS ENHANCEMENTS is presenting a series of FREE seminar workshops specifically focused on the new FireStore FS-3 camera mountable DV disk recorder and DTE© Technology. You can learn how only DTE© Technology allows you to record and digitize in your NLE’s native file format: OMF files for Avid, Quicktime files for Apple FCP, or AVI type2 files for Adobe Premiere. Learn how you can improve your workflow, save time from acquisition to post production, and use the latest in professional DV disk recording technology.
LEARN HOW to SHORTEN your WORKFLOW with Focus Enhancements DTE© TECHNOLOGY:
There will be many different NLE output solutions shown at each location, including: Apple, Avid, Canopus, etc and you will get a chance to see how well the new FireStore FS-3 works with different NLE solutions such as Apple's Final Cut Pro, Pinnacle Edition, Avid DV Express, etc. I will be on hand to demonstrate the new FireStore FS-3 in tandem with DV cameras such as the Canon XL1S and Canon GL2 and other cameras such as the Panasonic AG-DVX100, JVC GY-DV5000, Sony PD-150, DSR250 and DSR300A, among others.
http://www.focusinfo.com/roadshow
Chance to win a FireStore FS3 at each location!
See special dealer discounts and promotions
See the latest digital video technology
Talk to industry experts
Understand how “Direct to Edit” DTE© Technology can improve your workflow and save time and money
Table Top exhibits from participating resellers, showing a complete solution from capture (camercorder with FireStore FS-3) to editing (NLE) will be available for browsing during the day. Refreshments will be available for each session.
Presentations will be scheduled with applications on "Improving the Video Acquisition and Editing Process" using the FS-3, and solution packages from Final Cut Pro, Avid, Matrox, Canopus and DV Camcorders from Sony, Panasonic, JVC and Canon. These presentations will be 20-30 minutes in length. Other Resellers, Camcorder Reps., or NLE Reps are likely to be represented as well.
Morning Workshops will be targeted towards the Event Videographer.
Afternoon Workshops will be scheduled for the Broadcast market.
A complete schedule will be provided upon arrival.
Here is the schedule so far:
September 23: Houston, Texas
September 25: Dallas, Texas
October 8: San Francisco, CA
October 28: Miami, Florida
TBD: Burbank, CA
TBD: New York City
TBD: Chicago, Illinois
TBD: Boston, Massachusetts
REGISTER NOW for FREE:
You can register for free, simply click on the link to the right and fill out the required fields at http://www.focusinfo.com/roadshow/reg.htm If you do not get a chance to register, you may still attend but the cost will be $10 at the door.
You may attend both sessions and all are invited!
Hope to see you there,
- don
Old September 21st, 2003, 04:08 PM   #37
Images: 10
ADS has put their DV HD recorder up on their website, 20 Gig HD, direct recording from DV cam...$700. On board lithium battery charges via the firewire connector or external PS. I've ordered one to check it out.
Old October 1st, 2003, 02:14 AM   #38
someone should just right some software for a laptop that does this with minimal setup. Just a nice quick record, pause, stop program and that all it does, maybe ad in a database/thumbnail system. Not sure whats required for the camera to control it but worse case senario is that you rig a small wired remote with a few buttons on it to mount on your tripod. This would be sweat because all you would need to make your own recorder would be, and nice small motherboard (like a via epia w/firewire), a nice 300+gb HD, (could be hot swapable for multiple harddrives and loading footage into the editor of choice. a 12v PS (like if you would be doing a car install), build a 12v batterypack out of 10 rechargable C's or D's. The OS could just be a striped down version of linux, setup to run without a display. Might be nice to setup a small 4x40LCD to give some read out on what the unit is upto. could proubly make it about 10inx10in (most likely smaller) at the biggest. granted it wouldn't be the smallest but would sure hold alot of video. adding it up in my head I still comeout to around 600ish. about half that going into the HD so if smaller HD was needed would be less.
Hehe this proubly would be unrealistic its just my geekish side thinking
Jon Kamps is offline   Reply With Quote
Old October 15th, 2003, 07:55 AM   #39
Found a comparison chart of current Firewire storage for DV. Enjoy!
http://www.focusinfo.com/products/firestore/matrix.htm
"God is good, life is hard, Heaven is sure"
Camille Daily
Fat Cat Media
Roze Ann is offline   Reply With Quote
Old October 15th, 2003, 08:03 AM   #40
Images: 10
this list is either out of date or definitely biased because there are several incorrect entries.
Old October 15th, 2003, 08:53 AM   #41
<<<-- Originally posted by Jon Kamps : someone should just right some software for a laptop that does this -->>>
On the mac you can capture directly to your hard drive using a little shareware program called BTV Pro. I've been using it as an external monitor via firewire but haven't tried the recording functions. But I believe you could also capture directly in your NLE software running on your laptop (Mac or Windows).
Old October 15th, 2003, 10:10 AM   #42
changed my mind
In my original post, I lauded the abilities of the Laird system. Well I just saw the Focus Enhancements FS-3 system and ............WOW!
Compact, elegant, swapable hard drives (40 and 80 gig), multiple formats.
Price: $1999 retail, probably less on the street.
I just finished my second short film where I was the DP. I had 19 hrs of DV in my computer in less than 30 minutes. It took me 27hrs of time to capture from tape on my first film.If my time was worth a modest $50 per hour that's $1350 in lost time.
One film almost paid for the unit. I'm real happy with the Firestore product line.
Their office and manufacturing plant is a mile from my house so I could go and talk to the tech guys personally. Very helpful and friendly staff. That's important me.
Once again, highly reccommended.
Regards,
David Mesloh
Old October 15th, 2003, 10:21 AM   #43
Moderator
corrections?
- Hi Bill,
What exactly would you suggest is incorrect? I would be interested in hearing your input. If anything is indeed incorrect as you suggest, it will be duly noted and addressed as such.
Please do elaborate. If anyone else has some comments to make, please do chime in!
Thank you,
- don
Old October 15th, 2003, 10:26 AM   #44
Warden
I think Bill is referring to Roze Ann's link and not this thread.
Jeff Donald
Carpe Diem
Old October 15th, 2003, 11:02 AM   #45
Images: 10
yep...referring to the comparison list at the Firestore site. I have an ADS DV drive and it has much more capability than this list implies.
Bill Ravens is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
