Coming Soon — More Airspace for Drone Operations
FAA Safety Briefing Sep 2 · 5 min read By Peter Sachs, FAA Unmanned Aircraft Systems Integration Office Drone pilots will have even more options than before when they seek permission to fly in controlled airspace this fall. The Low Altitude Authorization and Notification Capability, or LAANC, is getting a big enhancement that will enable drone pilots to operate in even more low-level airspace than before — and to know that they’re doing it safely. Currently, the FAA divides the airspace around nearly 750 Class B, C, D, and E airports into grids that are each about one square mile. Each grid cell has a maximum safe UAS (unmanned aircraft system, or drone) operating altitude, on which FAA air traffic facility staff, controllers, and managers collaborate to determine. This is the highest altitude that is deemed safe for UAS to operate within each cell with an automatic approval through LAANC. These altitudes can range from zero (no flights allowed without further coordination, such as in areas above and immediately adjacent to airports) to 400 feet above ground level (AGL). The grouping of these grid cells comprises the UAS Facility Map, or UASFM, for a volume of controlled airspace. “The FAA is calling the enhancement ‘Quad Grid,’ explains LAANC Project Lead, Victoria Gallagher. At present, drone operations can’t be automatically authorized in some cells away from airports, especially where hospital heliports are located, or where approach and departure paths clip one corner of a cell. That effectively locks out drone pilots from an entire square mile, when generally only a smaller area needs to be protected for crewed flights. Figure 1: Current one square mile UAS Facility Map cells around Chicago Executive Airport (KPWK) are shown in green. With Quad Grids, represented by the additional blue lines, cells will be much smaller than before. Figure 2: Consider the Class D airspace near Chico, CA. The UASFM altitude limit in two grid cells in the southern edge of this airspace is zero due to a hospital that falls within both grids. Following the transition to Quad Grids, many of the resulting eight cells will have a much higher altitude limit. Therefore, more of the Class D airspace would be available for automatic approvals. The FAA has planned an assessment to collect metrics and assess benefits in areas such as this one following the transition to Quad Grids. Once Quad Grids go into effect in the fall of 2021, each of those previous grid cells will be split into fourths, making the new Quad Grid cells about ½-mile on each edge. This holds the potential to safely open up airspace for drone operations in hundreds of locations across the United States by allowing UAS flights in some of the newly subdivided cells. Because each LAANC UAS Service Supplier (USS) visualizes airspace differently, UAS pilots may not immediately recognize the four-fold increase in the number of UASFM grid cells, but under the hood, that’s what will drive the difference in how airspace authorizations appear. Since its inception in 2017, the LAANC system has worked well for the FAA and many commercial drone pilots who operate under part 107, as well as recreational pilots flying under Title 49 of the U.S. Code, Section 44809. In fact, the FAA’s approved LAANC service providers have now processed more than 700,000 authorizations, the vast majority of which happen automatically and in a matter of seconds. But UAS operators have been asking for more flexibility, and that’s where Quad Grids come in. “A square cell that is a mile on each edge doesn’t naturally fit well with airspace boundaries, which are often circular,” Gallagher notes. The Quad Grid upgrade also gives air traffic control facilities more flexibility and precision when determining the maximum altitudes to set for each UASFM cell in their airspace. The current grid works well for airports with east-west and north-south runways, but facilities must be overly conservative to protect airspace underneath the approach and departure paths for diagonal runways. Once the new Quad Grids go into effect, facilities will have the option to be a bit more precise, based on their local traffic patterns. This could mean allowing UAS operations at 50 or 100 feet AGL, for example, adjacent to approach paths, if the facility determines doing so is safe. “This has the potential to open up literally hundreds of square miles of airspace to drone pilots across the National Airspace System (NAS), without impacting the safety of operations for crewed aircraft,” says Gallagher. Drone pilots would still be required to follow all other FAA regulations, such as registering their aircraft, flying within visual line of sight, and giving way to crewed aircraft. Figure 3: Current UASFM assignments around Beverly Regional Airport (KBVY). The final approach for Runway 16, depicted with the pink arrow, clips the corner of one cell with a “0,” indicating no automatic approvals. With Quad Grids, each facility would have the option to adjust altitudes in new, smaller cells (for example, the one shaded purple) that are farther from high-traffic areas. Quad Grids are just one of many initiatives underway in the FAA to enable the safe integration of UAS into the NAS. Earlier this year, new rules went into effect that are making it easier for qualified UAS pilots to safely fly at night, or over people. The FAA has also started an Aviation Rulemaking Committee (ARC) focused on beyond visual line of sight operations. The ARC comprises about 90 representatives from across industry, local governments, tribal bodies, and others that will recommend changes to FAA rules and regulations with an eye toward further enabling the safe integration of advanced UAS operations. The FAA is also looking at how to leverage its years of historical surveillance data to analyze airspace usage by crewed aircraft. Visualizations could help identify areas of uncontrolled airspace with frequent crewed aircraft activities, where UAS pilots would continue to need additional collision avoidance mitigation measures. The initiatives could also help in identifying times of day when crewed aircraft operations are less likely to occur. That opens the door to exciting new possibilities of dynamic airspace management, by enabling further UAS access in complex airspace, without limiting general aviation operations or increasing collision risk. Peter Sachs is a UTM implementation program manager in the FAA’s UAS Integration Office and previously worked as an air traffic controller at San Francisco Tower (KSFO) and Chicago Executive Tower (KPWK). https://medium.com/faa/coming-soon-m...s-358fb82447a9 |
