BBC Article - Hexacopter
Re: BBC Article - Hexacopter
I just came to post that link. It's a fascinating article and a nice demo. I cannot make out what camera they are using. It's small but it's not as I expected an XF100 (which has EBU/BBC approved 50Mbps CODEC). Any guesses?
#3 | |
There was a story a while back about BBC News buying JVC HM650s for self-shoot journalist use, as amongst other reasons it shares the XDCAM EX codec with the bigger cameras. Could it be one of those? |
I have just double-checked with the BBC video at full screen & I can clearly see at 00:42 that it is a Panasonic Lumix G6 (I have one so can compare it with the screen. It also looks very like the lens is the Panasonic 14mm F/2.5 that I have on mine.
The G6 does have fantastic quality video but it's AVCHD or MPEG4 and not even 35Mbps. |
#5 |
This is probably being used as what could be termed a speciality camera, rather than the main camera. In news the BBC regularly use internet links, which are definitely not of a broadcast standard. What is acceptable for news may not be acceptable for mainstream HD programmes, although the latter also sometimes use lower standard material, which fit into the SD percentage that a HD production is allowed.
#6 |
I knew these copters would eventually be used by news reporters. You just can't beat the quality of footage you can achieve with these things. Angles you simply can't get with anything else! I like the way they emphasized the fact the operator had been trained for 6 months and acquired a license! almost as if they were implying users at home not to go out and buy one and start flying it around their next door neighbors garden lol
#7 | |
#8 |
You can find the list of BBC approved cameras on their and on the EBU web site,. There are tiers of cameras and what might be suitable as the main camera on a news programme mightn't be the case on a programme.
In selecting a camera for this type of work, how it handles vibration might another consideration. A trained operator would be part of the BBC's health and safety considerations, apart from it being a CAA requirement. |
#9 |
I don't care much about what a bbc approved camera is, I often see a lot of people get exited when they have a camera that is on that list but I guess they are supplying material to the BBC or are working in any form of newsgathering where their camera needs to be up to a certain standard. I only found it interesting to see they also use this cheap combo from Panasonic.
#10 |
The BBC also use GoPro cameras, it's a case of the right camera for the job. There are other options, but you do get into heavier cameras using better codecs and higher costs, which mightn't be justified in the particular circumstances here.
The BBC has also mounted cameras on eagles. In the past they've used lipstick cameras that gave awful looking pictures. It's part of a tradition that goes back to the use of 16mm gun cameras, which did give rather good pictures. |
#11 |
As said many times before, the EBU guidelines are just that - recommendations, not "rules" or "laws". That said, they are based on some sound science, consequently there is a lot of sense in taking note of them even if your work isn't for broadcast.
And as also said many times before, the use of non-approved cameras is not a problem if something like "practical operational need" can be proven. In other words, if you're doing undercover work with a hidden camera, nobody is going to force the use of a 2/3" camera underneath your raincoat......:-) That's no excuse for thinking you can therefore use a cheap camera just to save yourself money. |
#12 | |
#13 |
I couldn't give a flying tosh about BBC's list. My client's don't require a BBC approved camera.
I buy my cameras after seeing what it is capable of and how difficult it is to get such imagery. That's how I make my purchases. |
#14 |
Yeah but you better be prepared to put on a raincoat. :) I wonder if there is any footage available shot with that hexacopter and g6 combo that is of higher quality? The link to that footage that Pedanes posted is heavily compressed.
