Custom Message in WMV Status Bar at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
Old June 7th, 2007, 10:27 AM   #1
I'm creating video for someone's web site and want to put my own URL in the status bar for viral advertising. What code could I use to do that?
<OBJECT ID="MediaPlayer" WIDTH="534" HEIGHT="344" CLASSID="CLSID:22D6F312-B0F6-11D0-94AB-0080C74C7E95"
STANDBY="Loading Windows Media Player components..." TYPE="application/x-oleobject">
<PARAM NAME="FileName" VALUE="http://legacyhdv.com/07fashionshow.wmv">
<PARAM name="autostart" VALUE="true">
<PARAM name="ShowControls" VALUE="true">
<param name="ShowStatusBar" value="true">
<PARAM name="ShowDisplay" VALUE="false">
<EMBED TYPE="application/x-mplayer2" SRC="http://legacyhdv.com/07fashionshow.wmv" NAME="MediaPlayer"
WIDTH="534" HEIGHT="344" ShowControls="1" ShowStatusBar="0" ShowDisplay="0" autostart="1"> </EMBED>
</OBJECT>
www.LegacyHDV.com
Weddings | Corporate | HMC150s | FCPX | Encore | Lion
Dana Salsbury is offline   Reply With Quote
Old June 7th, 2007, 01:40 PM   #2
You will need to put that information in to the video before encoding it.
I cant remember where it is of the top of my head but is somewhere there when you are setting bitrate and video size etc, you can set author info copyright etc
Then in your code you will need to set showstatusbar or showdisplay to true.. Maybe both like this
<OBJECT ID="MediaPlayer" WIDTH="192" HEIGHT="290" CLASSID="CLSID:22D6F312-B0F6-11D0-94AB-0080C74C7E95"
<PARAM NAME="FileName" VALUE="videofilename.wmv">
<PARAM name="ShowDisplay" VALUE="true">
<PARAM name="autostart" VALUE="false">
<EMBED TYPE="application/x-mplayer2" SRC="videofilename.wmv" NAME="MediaPlayer"
WIDTH="192" HEIGHT="290" ShowControls="1" ShowStatusBar="1" ShowDisplay="1" autostart="0"> </EMBED>
</OBJECT>
But you must make sure that the info is encoded to the video first.
Unless you are meaning some other way? Then im not sure!;-)
James
http://www.uvrx.com/
James Watt is offline   Reply With Quote
Old June 8th, 2007, 11:39 AM   #3
Thanks James. Spot on. I was looking for a way around that so that I could custom code my web videos depending on the use, but I guess I can built one consistant message from the beginning.
www.LegacyHDV.com
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
