Compressor questions at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
Old January 30th, 2007, 02:23 PM   #1
Hi,
I'm trying to compress for web using Compressor. Previously I used FCP/QT.
AUDIO
I've used IMA 4:1. Compressor's default is AAC. What is AAC, and is it better to use than IMA 4:1? Larger, too?
My films are mostly under 10 minutes. I used AAC choosing Mono, 32khz. Would you suggest any changes in these defaults?
Render Quality: Normal
Bit rate format: Constant bit rate
Target Bit Rate: 48kbps
Precedence: Bit rate
VIDEO
I chose 'Web Download QT7 H.264 300kbps'. Ok?
Any info would be appreciated.
thanks,
elmer
Elmer Lang is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
