#16 |
Sure, go ahead and send it to me via private email. The smaller the file the better and I'll encode it with the suggested settings.
Mark videos: http://vimeo.com/channels/3523 Stock: http://www.pond5.com/artist/mark29 |
#17 |
What I found most intriguing was it seems that the sound stayed in sync, although I wasn't totally sure because there were no talking heads.
Quality was very good. On my old Imac (with maxed out ram), It looked like I was seeing about 6-8 frames per second. The fuel guage that shows how quickly the image is loading seemed to be moving perfectly along, actually ever so slightly moving faster than the elapsed running time of the video. ----------------------------------- I had a question about the fallen tree. I assume it was a fallen tree, no? It definitely adds an interesting visual element to the video, but it made me wonder what it took to make the tree fall, which for me slightly contradicted the serene mood you otherwise effectively created.
https://alexlogic.blogspot.com/ Los Angeles Emmy Winner (yes, used a video edit controller and loved doing so.) |
#18 |
Good question. When most people think of Florida beaches they think of lots of sand, sea oats and sand dunes. Cape San Blas is a very unusual place in that half of the peninsula is dunes and on the other half the tree line (mostly pines) goes right down to the high water line. As the tree roots erode and the trees fall into the ocean it makes for an unusual sight with the twisted, weather worn and polished wood. Also, this area has been hit with 3 huricanes in the past 3 years. When framing that shot I tried to show how the forest was intertwined with the ocean and how it was on the loosing side of the battle between land and water.
Regards,
#19 | |
#20 | |
Some great close-ups of the water fowl. What did you shoot this on, if I may ask? regards, -gb- |
#21 |
Thanks Greg,
It was shot with a pany DVC-30 all on a tripod. This shoot was one of those occurances when I felt I was in the "zone". Of course it helps when no matter which way you turn there is something photogenic. Regards,
#22 | |
the quality looks great. My material is SD avi and I am using Vegas 6. Any suggestion which settings could result in similar quality? |
#23 |
That footage indeed looks superb!
I've been messing with different codecs and settings the last few days now to get my footage as clear as possible to put in on youtube, but it just isn't right yet. I export my movies from final cut pro with Quicktime Conversion, with the MPEG-4 codec, at 30 fps (all my movies are shot on 25fps), and 'Keyframe' and 'Data Rate' settings set to 'automatic'. I try to keep the quality set at 'Best', except for the movies that are 6minutes or longer, because then I have to set it to 'High' to stay within their 100Mb limit. Doing so I feel that I just don't do justice to my films, as there is way too much artifacts and quality loss going on! At least the sound sounds good (settings: apple lossless, 48kHz, Best Quality). ...But I'll try to compress them with the H.264 codec now! I also heard that Sorenson 3 is an interresting compression to yield high quality with small files..!? Any suggestions on the audio settings? (Maybe this takes up way too much space?) Also, is it normal that with a 6minute (or longer) movie file, at those settings, I'm getting over the 100MB?? If you want to have a look at the quality: the link is in the sig... Thanks in advance! |
#24 |
Have a look at: http://www.dvinfo.net/conf/showthread.php?t=95625
#25 |
YouTube accepts .avi, .wmv, .mpg, .mov
File size limit is 100 MB Time limit is 10 min for cobverting, compressing & stuff have alook at VidCrop http://www.geovid.com/VidCrop/ |
#26 |
Just make sure to not compress your already compressed video files when exporting to a different file format.
#27 |
Look what I found...
http://forum.videohelp.com/topic346256.html
Sincerely, Renat Zarbailov of Innomind.org |
#28 |
That's a VERY interesting link! Thanks for sharing!
| Thread Tools | Search this Thread |
