How important is Frame Mode? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
Old April 3rd, 2003, 09:02 AM   #1
I will soon buy a camcorder and likes the Sony PDX10 because of it's 16:9 functions. But... I want to make video's for websites and will be using Cleaner 6 for compression.
My question: How important is it to shoot in FrameMode when shooting for web? What is the difference in this case from shooting in "normal" mode?
The Sony PDX10 has no frame mode ao maybe I should concentrate on my second choice - the Canon XM2 ?
Bjorn
x
Bjørn Sørensen is offline   Reply With Quote
Old April 4th, 2003, 09:26 AM   #2
RED Code Chef
For the web it should not make any difference because you will
through away at least 50% of your resolution. Only if you retain
your full resolution will it become important (shoot frame mode
then!). Frame is better for a PC because you don't see distracting
interlacing lines. But if you are going to do low resolution web
files it will not matter which method you choose because you will
loose one full field at least and so you will not see the effect!
Rob Lohman, visuar@iname.com
Rob Lohman is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
