Export from Flash to QuickTime: "required QuickTime component not found" at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
Old September 25th, 2006, 08:03 PM   #1
What am I doing wrong? I have a short Flash movie sequence that I would like to export to q QuickTime .mov file (or, for that matter, anything else I can import into Final Cut Pro). When I try to publish to a QuickTime file, the following error message shows up:
An error occurred because a required QuickTime component could not be found.
I am running Flash 8 Professional (trial version) and QuickTime Pro 7.1.3.
Thanks in advance for your help!
- Martin
Martin Pauly is offline   Reply With Quote
Old September 25th, 2006, 08:14 PM   #2
Just found a workaround. Apparently, in the latest version of QuickTime, support for Flash is disabled unless explicitly enabled in the system preferences. Once that was done, I could import the .swf file into QuickTime and convert it to a .mov file. I still get the same error message when trying to export to QuickTime directly from Flash.
- Martin
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
