How can I convert mp4 to a .swf file in Sorenson Squeeze 9 Pro? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
Old April 4th, 2014, 08:34 AM   #1
Hi Guys
Any thoughts or suggestions most urgently welcomed!
When I press squeeze I see ".swf" as it is processing, but as the squeeze finishes it changes to .flv
I've used the each of the Formats "Adobe Flash Movie (.swf)"--but they keep outputting as .flv
The web guy here says his system only works with .swf files, and that the file was really bad quality and sound once he changed the extension of the .flv file to .swf.
Warm regards
Peter Dunphy is offline   Reply With Quote
Old April 6th, 2014, 04:18 PM   #2
Equal Opportunity Offender
Re: How can I convert mp4 to a .swf file in Sorenson Squeeze 9 Pro?
From memory, .flv is the actual video format that is referenced from within the .swf (vector animation objects) Flash animation file.
Andrew
Old April 9th, 2014, 03:05 AM   #3
Thanks Andrew, appreciate it. Our web guy has figured out how to export from FLV to SWF using flash.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
