Bit rate Poll at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
Old May 28th, 2002, 11:56 AM   #1
Bit rate Poll
Here is the question what bitrates must be covered for a video file to meet a large audiance? In other words what bitrates should you always include when creating Video for the web?
Here is my answer:
22 Kbps
36 Kbps
90 Kbps
290 Kbps
Best,
James
James Rulison is offline   Reply With Quote
Old May 29th, 2002, 02:29 AM   #2
RED Code Chef
That depends heavily on what compression system I would use.
I prefer quality over size (up until a certain point ofcourse). For
mpeg I'd use a large bitstream then for quicktime.... It also
depends for me on total size. If a movie is shorter I might use
a bit larger bitstream so that viewers enjoy a higher quality.
For a larger movie I might cut it down a bit to don't have
enormous files.
Rob Lohman, visuar@iname.com
Old May 29th, 2002, 03:08 PM   #3
Air China Pilot
When I encode in my company's Clipstream Video format we provide:
500,
300,
256,
128,
and
40kpbs bit rates.
Keith Loh is offline   Reply With Quote
Old May 30th, 2002, 11:30 AM   #4
_redone_
that all depends on what your doing..
i post my 30-60 second TV spots on the web at 240x190 Quicktime Sorenson.
at maybe 600kb. seems to make a clear picture plus maybe under a Meg
in file size.
Though if your showing anything longer i would recomend a quicktime
streaming format at a Sorenson 200-300kb.
I couldnt imagine a bit rate under 100kb...seems it would be impossible to see at a larger window size.
The Streaming format works the best for movies or full length videos..
since it plays while downloading.
You can also manually compress your video through any NLE system..
before formatting it, simply by cutting the frame rate down to 15fps
and applying a mosiac when possible.... this helps a ton for short videos
Adam Lawrence
eatdrink Media
Las Vegas NV
www.eatdrinkmedia.com
Adam Lawrence is offline   Reply With Quote
Old May 30th, 2002, 01:04 PM   #5
Air China Pilot
>I couldnt imagine a bit rate under 100kb...seems it would be >impossible to see at a larger window size.
People with bitrates under 100kb (modem users) must get used to viewing postage stamp-sized video or at least video with dropped frames. When you deal with webadvertising like the company I work for, that still makes sense because webadvertising already understands the low bandwidth model. So, a small talking head or 30 second commercials works great streaming.,
>The Streaming format works the best for movies or full length >videos..
You would think so but movie and music video people are extremely picky about the quality of their video so they are loathe to provide a streaming video. They would rather people put their modems on download all night. My company is changing this attitude by working with marketing companies that understand web advertising. Those nerds who really want that 640x480 quality QuickTime will spend their time and bandwidth doing that. But that's a small component of advertising.
People here advertising their own work should realize that first they have to grab attention and pitch their message before they show off the quality. No one is going to go to their sites to wait on a download unless they first are attracted by something. Quick streaming videos can work that way.
Old May 30th, 2002, 03:02 PM   #6
_redone_
true...
though when you are dealing with web and video, you should build it as if
monkeys are your audience....saying this, nonone with half the computer knowledge as you and I arent going to wait 2 hours for a 56m video to download (if they even know how) on a 56k.
I prefer a streaming video, and in the same sense a video in which does-not
view through a pop-up window. This due to the users reaction time...
The video plays or loads as soon as the user clicks the link, thus keeping the
attention of the user and insuring the video to be played in a sufficient fashion.
I always build my videos small.... at max 320x240 - sm 190x120.
even though these may seem small on the producers screen with our 1200x resolution size, some poeple are still topping 800x600..which in turn will make
the movies very viewable.
Big is not always better.
Adam Lawrence
eatdrink Media
Las Vegas NV
Old May 30th, 2002, 04:20 PM   #7
Air China Pilot
<<<-- Originally posted by _redone_ : true...
You might be interested to see our technology, then, because one of our selling points is that we do not break the user out of a web page to launch a player that may have someone else's advertising. We allow the web page designer to embed the video into the page itself. I've already mentioned our product so you can do a search for it on Google so I don't violate the huckster rule on this board.
Hopefully by the end of the month my company will be able to spring for the GL1 that I'm advocating for and we can do some DV cam -> our product comparisons.
Old June 2nd, 2002, 06:53 PM   #8
We dont bother with dial up postage stamp sized video. We encode in Flash 4 at 128kbps to 700kbps. 240 x180 to 800x600 and anything in between.
whiterabbit is offline   Reply With Quote
Old June 3rd, 2002, 10:13 AM   #9
Air China Pilot
When you say that you encode in Flash what is the underlying video codec, anyway?
Old June 3rd, 2002, 05:09 PM   #10
No video codec. Its just a video clip exported as sequences of images, either jpgs or png's (if you want a transperant background). The only thing that keeps it from being ordinary Flash is that we later optimize the swf with our own software to remove the limitations of the Flash player.
The viewer does not need anything besides flash4 (if using streaming sound) or higher.
check out my resume, its a good example of a short flash video within a flash media player (you dont need the player) embeded on the page. For grins take the poll, the link is on the player, so you can see how well Flash and video can mix with PHP and MySQL. The graphs at the end are created with action script in Flash.
If you could see what went into it you would laugh, its very basic.
cheers.
resume
mantaproductions.com/jorge
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
