H.624 HD Web Delivery using Vimeo at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
Old August 13th, 2008, 06:18 PM   #1
I'm having problems viewing movies exported as Quicktime h.264 @ 1280x720 on my dual 1.8 G5 power mac.
When the output size is larger than 740x360 there are so many drop frames it looks like a photo slide show instead of a video. I can only watch it once it has been uploaded to Vimeo. I'm having a hard time getting it to look good on Vimeo.
Is my system too old or am I exporting it wrong?
Old August 15th, 2008, 01:33 PM   #2
Where does it look bad, in Quicktime or in Vimeo?
Aric Mannion is offline   Reply With Quote
Old August 15th, 2008, 06:22 PM   #3
1. My mac G5 can't play HD sized movies encoded in H.264, it seems to be a very cpu intensive codec
2. The other issue, was when my movie was uploaded to Vimeo the quality went down significantly. I think this is because 1) Vimeo recompress the movie you upload and 2) My video has fast motion and constant change, which doesn't react well to their compression. Notice how bad they look full screen.
I'm going to try hosting smaller dimensioned movies on my site instead of Vimeo and might use VP6 codec instead of H.264.
Here are links to the movie posted on Vimeo and I'll repost when I upload my own flash version on my site.
2008 West Indies Parade (SD widescreen) on Vimeo
2008 West Indies Parade (High Def) on Vimeo
Old August 15th, 2008, 08:39 PM   #4
Check your bitrates. You can also allow the download of the original file as a different higher quality means of delivery.
Old August 16th, 2008, 02:59 PM   #5
If you use the new FCS 2 just use the Apple TV codec for 720p even with 1080i footage. It looks great on vimeo. This is assuming it's not a computer issue.
Jon Bufkin
focalpointcinematic.com
Jonathan Bufkin is offline   Reply With Quote
Old August 17th, 2008, 12:34 PM   #6
Here's the same video uploaded to my site instead of Vimeo. I'm using 5mbs (half of what I used on Vimeo and it looks much better).
http://creationdream.com/samples_video.php
One of the down sides of not posting on Vimeo is that movies don't stream. You need a special steaming server for that feature.
Pete Cofrancesco is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
