Adobe Crashes With Flash at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
Old March 19th, 2008, 01:18 PM   #1
Recently Upgraded From PPro 1.5 to CS3 and attempted to render a short clip (about 30 seconds) into a Flash file. I have tried this in both Encore and from a Premiere project time line, using the Media Encoder.
Both methods shut down the programs. They are replaced by a two message boxes that I do not comprehend. One is a Red X box warnng of a Runtime Error, the other is a dos message with some gibberish about "OMP abort"
I called Adobe support and they didn't have a clue.
Any thoughts?
Jim Long is offline   Reply With Quote
Old March 21st, 2008, 09:46 AM   #2
Two questions: Do you have Cineform installed and are you on Vista?
The same problem appeared after I installed a Cineform trial. Flash worked fine before the install, then died. Despite some detailed instructions from the Cineform folks, I don't think their software ever fully uninstalled. Tried uninstalling CS3 then reinstalling. No joy. Ultimately, I had to blow away the system and reinstall everything from the OS on up. All is fine now but I am very reticent about trying Cineform again. I do not believe that Cineform is ready for Vista yet.
I never contacted Adobe support since i couldn't play silly buggers looking for the cause. I just needed to get back running again.
Old March 27th, 2008, 09:27 AM   #3
Had similar issue... I gave up...
I too ran into the encoder issue from Premier Pro to .flv. Don't remember the exact error message(s), but discovered Riva. It's a free .flv encoder which seems to always do the trick. While I've returned to Adobe Flash in their encoder on occasion I have discovered way too many times it fails to deliver. So, back to Riva. It's small, fast, and dependable.
Give it a try.
http://www.rivavx.com/?encoder
Here's links to a couple of things I encoded recently with it:
http://promotion.denvermho.com/musicalstyle/
http://promotion.denvermho.com/corporatepromo/
http://www.econoclips.com/index.php?...&products_id=4
Kendall Media Group
econoclips.comeventon.tv
Last edited by Craig Kendall; March 27th, 2008 at 09:32 AM. Reason: Added example videos
Craig Kendall is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
