Convert Video to .FLV? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
Old January 23rd, 2008, 03:55 PM   #1
I have many SD projects in Final cut pro, that I need to convert to .flv with some very specific settings:
Constant Bit Rate
VP6 codec
progressive downloading, not streaming
data rate of 400 kb/s
audio compression of 64 kb/s
What Mac program would you recommend for this? ffmpeg? Flash? Something else? I don't have much time and I'd like to know what works best.
Aric Mannion is offline   Reply With Quote
Old January 23rd, 2008, 04:07 PM   #2
I like using After Effects CS. It did the best job of all I tried.
Jon Bufkin
focalpointcinematic.com
Jonathan Bufkin is offline   Reply With Quote
Old January 23rd, 2008, 08:12 PM   #3
Sorensen Squeeze with the professional codec plug-in works well.
Eric Darling is offline   Reply With Quote
Old January 24th, 2008, 09:49 AM   #4
The video encoder that comes with Flash can do that. I don't know if that one is different than what comes with After Effects - but since both are made by Adobe, they could very well be the same.
- Martin
Martin Pauly
Martin Pauly is offline   Reply With Quote
Old January 24th, 2008, 09:54 AM   #5
I don't think they are the same. I couldn't get the Flash encoder to look good at all. After Effects uses a version of the On2 encoder I think.
Jon Bufkin
Old January 24th, 2008, 11:10 AM   #6
After Effects it is then, thanks
Old January 24th, 2008, 05:28 PM   #7
I use On2 Flix Pro and Flix Exporter. You can purchase these from On2.com. Flix Pro is a standalone app, and Flix Exporter is a plug-in you can add to QT Pro, which gives you the export functionality of Flix Pro as export options from QT Pro.
I recently purchased Sorenson Squeeze, which I understand will be able to use my On2 installation to add VP6 export options to the Squeeze Suite, but I haven't tried that yet.
I did a lot of reading up on this some time ago, and read a detailed demo and review comparing the output quality between the On2 product and the options provided through the Adobe applications. I don't remember where I read it or what the link would be, but I do remember the end result stated that although there are a few advantages in some instances of the Adobe options, the better quality was generally achieved using the On2 Flix product. I am not sure if this was due to 2-pass options or something else because I can't remember what the limitations of the Adobe After Effects or Flash output were.
-Jon
"Are we to go on record, sir, with our assertion that the 'pink hearts, yellow moons, orange stars, and green clovers' are, in point of fact', magically delicious?"
- Walter Hollarhan before the House Subcommittee on Integrity in Advertising - May, 1974
Jonathan Jones is offline   Reply With Quote
Old January 24th, 2008, 07:09 PM   #8
This is not the review I noted in the above post, but it does give more information than I was able to give.
http://www.studiodaily.com/studiomon.../hot/7744.html
-Jon
Old January 27th, 2010, 11:23 AM   #9
as for me i use Macvide VideoFlash Converter
Bredly Root is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
