Streaming of video from a server
In the past I have used Flash videos to stream video. The problem I ran into was when the Flash video was on a shared server that was hosting the site, it caused problems as it put to heavy a load on the server's CPU. Was wondering if I used an embedded Quicktime video instead would that still put a load on the server?
www.speedandmotion.com |
I think they do, who was your shared web host? I did hosting with 1and1 and it worked out well until I moved to a dedicated server.
I use GoDaddy. I did not have problems with my shared server hosting until I put up some HD quality/sized Flash videos. The shared server then became overloaded and I was told to take them down. What problems did you have with 1&1? My friend is thinking of using them.
I didn't have any problems really, I just finally got setup to where I can afford the montly bill of a dedicated server. Turns out most of my clients are OK with a montly bill for hosting their files so they dont have to deal with it or use youtube :) Only "problem" is common of all shared hosting which is its hard to customize things such as the version of ruby if you are trying to write some custom scripts.
#5 | |
Also, was this true streaming for just progressive download of videos? Thanks, Martin
Martin Pauly |
#6 | |
But then again it could have been to much bandwidth at one time. I had put up the videos and my bandwidth increased by about 10x once the web page started to get posted around the Internet.
#7 |
What's the data rate you picked when you encode the flash video? I tried 1mbps. The video looks good and streaming is smooth. However, data rate over 1mbps I am skeptical about it. A lot of people still using DSL on 384kbps bandwidth.
#8 |
Duane,
It was most certainly a bandwidth issue. That is a MASSIVE amount of bandwidth you're taking up if many people are downloading those videos and a little Go-Daddy account does not afford you that. Its not a CPU issue. The web server is simply opening up a file and giving it the user, a very trivial operation for it to perform. |
#9 | |
Looking at GoDaddy's hosting plans, even the smallest hosting plan has 250GB of data transfer. That's a lot of downloads, even with large files. - Martin
Martin Pauly |
#10 |
So GoDaddy is okay? I've used them for a year, but am starting to do a lot more with video, and am trying to put together a Flash Video Gallery w/ ActionScript 3.0. They're now making me pay more, and that's fine if they're not limiting me.
#11 | |
http://sorrentofilms.com/reel.html |
