fcp freeze imac g5 won`t turn on at DVinfo.net
Final Cut Suite
Old July 27th, 2007, 01:47 AM   #1
Hello everybody ,
Two days ago i was importing some footage from a mini dv tape using sony dsr-11 and ..fcp froze and a faded message pop up to my screen says : YOU NEED TO RESTART YOUR COMPUTER ..i did and i reopened fcp againg it works like another 15 minutes and the same message showed up again only this time after i shot the computer down it won`t turn on again i keep hearing the fan sound and the little rounded light on the power key but the system won`t start. any input would be appriciated.
thanx .
Sid Ahmed is offline   Reply With Quote
Old July 27th, 2007, 07:19 AM   #2
Turn off your computer, then turn it back on and hold down the apple, option, p and r keys, let it cycle for 5 chimes and then let go of the keys.
Your resetting thr p-ram. This may solve your problem.
Mark
www.sharkvp.com
Mark Bournes is offline   Reply With Quote
Old July 28th, 2007, 02:58 AM   #3
Thanx Mark for replying , i did and it works fine for a minutes and then it froze again and won`t be turnining on .
Old July 28th, 2007, 09:19 PM   #4
Could be a bad memory stick, or other hardware. I had a 24" iMac that would Kernel panic upon restart, or would run real super slow if it booted, bad memory. Took it to Apple and it was fixed.
Jim Fields is offline   Reply
