HDV over firewire on FCP 6
Anyone knows how to activate the HDV output over firewire on FCP 6 (as you can do with DV)? This set-up is available in the audio-video settings in grey only... so is not possible to choose it even when you have an HDV device connected. Maybe is necessary a video card?
Sounds like you may have a bad install. I would try re-installing or checking for updates for a start. What system do you have running FCP 6 on?
Can't be done.
HDV doesn't travel over firewire for monitoring in that way. You'd need a special video card that handle realtime HDV. |
#5 |
#6 |
My TV is Standard Def, so I never noticed anything other than it working.
#7 |
You never noticed your Hi8 camera wasn't HD? :-)
#8 |
#9 |
Blackmagic's Intensity card sounds about right for what you need. They also offer other solutions depending on your setup.
http://www.blackmagic-design.com/products/intensity/ |
#10 |
Does anyone know if this is a limitation of Firewire or a limitation of the software? Is RT HDV monitoring over FW something likely to be seen in upgrades of FCP?
