FCE vs FCS2 at DVinfo.net
Final Cut Suite
Old July 5th, 2007, 11:26 AM   #1
FCE vs FCS2
I am a newbie...so perhaps I just have something set up wrong...but it sounds like both of these programs have importing issues. Are there good programs for video editing on a mac book pro 2.16 core duo that don't have these problems.
Set up
MBP 2.16, 2gigs Ram, FCE 3.5, 1T Mybook, Xh A1, DVHS Cap
Tobin Strickland is offline   Reply With Quote
Old July 5th, 2007, 11:30 AM   #2
What kind of importing issues are you having?
Chris Harris is offline   Reply With Quote
Old July 6th, 2007, 09:38 AM   #3
I think I have it figured out now after talking to apple.
I do wish there was a way to capture only the clips I want instead of captureing the whole tape then editing.
Old July 6th, 2007, 10:16 AM   #4
Yes, it is called Log and Capture, and it can be time consuming. Once you do it a few times, you can do it with your eyes closed.
Jim Fields is offline   Reply With Quote
Old July 6th, 2007, 10:30 AM   #5
Unless they have changed it in the new version, Final Cut Express (which Tobin says he's using) doesn't have the Log and Capture function.
Old July 6th, 2007, 01:41 PM   #6
Exactly, I have to shuttle the tape on the camera then 'capture now'. That's the only way to capture individual clips in HDV.
Can you log and capture in FCS2? Is it simple and relatively painless?
(IMovieHD was incredibly easy to log and capture...but don't want the compression). DVHS cap wasn't bad but it seemed it lost come coding on windscreening and image stabilization...somehow that doesn't possible.
Old July 6th, 2007, 01:52 PM   #7
I did not know this, I have never so much as looked at FCE
Yes Tobin, FCS2 has a very nice log and capture that will allow you to log clips via timecode and batch capture only what you want from a tape.
Old July 8th, 2007, 03:57 PM   #8
Batch capture ??
So, to understand this process, let me summarize what I think you are saying.
You log the tape and write down the time codes start stop of each clip you want. Then input all those start stops into 'log and capture' and then batch capture captures all the clips as seperate clips at one time?
Right now with FCE I have to watch the tape find all my in out times, place the tape at each start, capture, stop...then move to the next one. Ugghhhhh.
This might be worth the money right there...thoughts?
Old July 8th, 2007, 04:24 PM   #9
You could do it that way, but the easiest way is that you put the tape in and start playing it. You hit "I" for every in point "O" for every outpoint and then have it log the clip. It puts a clip into your browser window every time you log one. Of course it has no media yet, but it just appears as an offline clip.
Then, after you've gone through the whole tape and logged the clips, you have FCP batch capture each clip and you walk away while it starts captures stops, starts captures stops, starts captures stops....
David Garvin is offline   Reply With Quote
Old July 8th, 2007, 05:11 PM   #10
I think that would be worth it for what I am doing.
Thanks for all the input.
