Compressor won't submit at DVinfo.net
Final Cut Suite
Old July 5th, 2007, 09:57 AM   #1
Having just installed FCS2, I tried to export from FCP to Compressor, but after prepping, when I hit submit I received this message:
"Please restart your computer or verify your Compressor installation is correct."
I tried the first, didn't work. I don't know how to do the second.
Any ideas?
I considered a reinstall, but in the installation window, Compressor says 'O bytes.' Maybe I have to trash and delete Compressor, I'd onnly trashed it before.
best,
elmer
Elmer Lang is offline   Reply With Quote
Old July 5th, 2007, 10:16 AM   #2
I had a issue on DVCPRO HD frame converter plugin didn't get erased and ended up conflicting. Maybe erasing will do.
Kaku Ito is offline   Reply With Quote
Old July 5th, 2007, 11:12 AM   #3
Actually, it says: "Unable to submit to Queue. Please restart your computer or verify your Compressor installation is correct."
@ Kaku Ito
When you say erasing, do you mean trashing and deleting Compressor and starting over?
I'd considered re-installing. But in the installation window where it lists the apps, it says Compressor, 0 bytes. Can I re-install with 0 bytes showing, or do I have to trash and delete Compressor first?
Old July 5th, 2007, 09:51 PM   #4
I will see if there's any official way of uninstalling.
What about trashing the preferences?
Old July 8th, 2007, 06:29 AM   #5
I am having the same exact problem!!!
Dave Pecunies is offline   Reply With Quote
Old July 8th, 2007, 08:43 PM   #6
Compressor
Me too! Sounds like something is amiss.
Cy Dodson is offline   Reply With Quote
Old July 8th, 2007, 09:58 PM   #7
Hey fellas,
On Apple Compressor forum there is a long long thread visited by many suffering souls. Not many answers, just complaints. I was a complainer. I finally had to bite the bullet, clean install and now Compressor works.
All that enormous hassle because of one app screwing up.
Good luck.
lmr
Old July 9th, 2007, 03:49 PM   #8
On that thread in Apple's Compressor forum is a post by macsepp. Maybe try it. Good luck!!!
"I agree with you. This is far away from being solved. There is a clean Deinsaller Script for each FinalCut Studio app or component missing. And it happens again and again.
There is another way which did work for me having simillar problems.
I removed Compressor with AppZapper! which deletes:
/Applications/Compressor.app
~/Library/Application Support/Compressor
~/Library/Preferences/com.apple.Compressor.CompressorSharedService.plist
/Library/Receipts/Compressor.pkg
Then I manually deleted under /Library/Framework/ the Folder Compressor.framework
Then I think the important step is actually an old problem, that is removing Qmaster. Some time ago I saved a link I found here in the forum for Qmaster Removal script which works just fine.
http://home.comcast.net/~kinggorilla...oveQmaster.tgz
Remove Qmaster and then do a fresh install of Compressor and Qmaster from your FCS2 DVD. Should work."
best,
elmer
http://elmerlang.com
A couple films:
Lunky Business (2:53) - Behind every great man is a kitty cat
http://elmerlang.com/LunkyBusiness.html
Comet (4:23) - Hip pitch piece for science ed
http://elmerlang.com/Comet.html
Like Bloody Lips (4:13) - What doesn't kill you makes you stranger.
http://elmerlang.com/LBL.html
Old July 9th, 2007, 08:57 PM   #9
I am glad you got that fixed.
When ever I start to have issues with FCS, I wont hesitate to wipe the hard drive and re-install everything. My time is to important to try to admin FCS to make it work. My first install (before the 1.1 update) did not go to well with me, so I zapped the drive and did a fresh one.
Anyway, glad to here is works for you now.
Jim
Jim Fields is offline   Reply
