2:35.1 aspect ratio at DVinfo.net
Final Cut Suite
Old June 28th, 2007, 09:04 PM   #1
2:35.1 aspect ratio
How do I achieve the above aspect ratio(motion picture format) using FCP 5.1? I search the forum for 2:35.1 but none.
Nathan
Nathan Supan is offline   Reply With Quote
Old June 28th, 2007, 09:17 PM   #2
Nathan,
There are various plugins that will matte the image to give it the 2:35.1 aspect ratio. Keep in mind, that this is a matte, so your sequence will still be (I assume) 16:9. Did you shoot in 16:9? If so, then I believe this is how you will achieve your desired aspect ratio. I'm not really sure if you would set up you sequence to the 2:35.1 ratio, perhaps others will chime in too.
I use Nattress plugs (I believe it's called 'widescreen').
Hope that helps.
Todd
Todd Giglio is offline   Reply With Quote
Old June 29th, 2007, 01:15 AM   #3
Yeah, there's a plug-in that comes with FCP that'll do the matte for you. Just check under the effects tab, it's called widescreen, and you can select from a wide variety of aspect ratios.
Chris Harris is offline   Reply With Quote
Old June 29th, 2007, 09:18 PM   #4
I found it from the Effect tab. Thanks for the help.
Old June 30th, 2007, 02:47 AM   #5
Might be an obvious question but what is this doing to the 16:9 image? Is it squashing it slightly or increasing the bars and 'writing' over your footage?
If I recall, somebody on here (Brian Luce perahaps?) shot with this in mind and attached hair lines to his viewfinder/LCD so he kept within the new ratio frame.
David Scattergood is offline   Reply With Quote
Old June 30th, 2007, 03:42 AM   #6
It's just putting black bars over your image, covering the upper and lower parts of your footage.
Old June 30th, 2007, 06:35 AM   #7
Cheers Chris - then I guess you would have to plan for this when shooting footage. I thought about trying this ratio on some recent theatre projects but I'd end up slicing off the foreheads of school children which seems a little wrong.
Thanks.
Old July 1st, 2007, 11:53 PM   #8
It is a lens thing, meaning you film your project in 2:35.1 with a lens that will do so. You will still have a 16:9 image that will look cropped if you use filters.
Jim Fields is offline   Reply
