NLE Mac / Final Cut questions from 2002 - Page 86 at DVinfo.net
Final Cut Suite
Old December 14th, 2002, 08:58 AM   #1276
Warden
I think you 'll have to do it in two steps. There are several cards available, but they only offer digital I/O. Then you feed the Output to an external D/A and you'll have your multi channels.
Look at RME HDSP 9652
http://www.rme-audio.de/english/index.htm
Mytek Digital
http://www.mytekdigital.com/8x96.htm
I believe Motu makes some also http://www.motu.com/
Jeff
Old December 14th, 2002, 10:12 AM   #1277
Jeff,
Thank you for the heads up. I will check out those sites and see what I come up with. I've got an MBox, but it does not offer the 4 channels that I am looking for.
Paul Sedillo
Image::Studio
http://www.image-studio.com
Houston, Texas
Paul Sedillo is offline   Reply With Quote
Old December 15th, 2002, 12:39 AM   #1278
Boris Caligraphy
For some (STUPID) reason my upgrade of FCP3.0 doesn't have the full Boris caligraphy, it has the basic text crawl etc. but none of the nice 3D font tools. can someone tell me if it's okay to snag a copy from someone else (hint hint) or is it a no no to do that even though I have paid for and registered FCP1.25 & the upgrade to FCP3.0
Mark
I'm humbled by the greatness that surrounds me.
Mark Austin is offline   Reply With Quote
Old December 15th, 2002, 01:36 AM   #1279
Retired DV Info Net Almunus
Mark,
Are you sure you don't have it? I'll bet that you do. It's a separate installation, not part of the main FCP3 installation.
You should also be able to download the update to the Boris Calligraphy plug-in's from the FCP3 pages at:
http://docs.info.apple.com/article.html?artnum=120118
Old December 15th, 2002, 10:01 AM   #1280
I'm sure I don't have it. It's not on my FCP1.25 install disk, and I scoured the FCP3.0 disk, and ran the installer from there, but it's definately a crippled Boris caligraphy version. I'll try the link you posted.
Mark
Old December 15th, 2002, 10:17 AM   #1281
well...
I downloaded and installed it and now I have: crawl, lower 3rd, outline text, scrolling text, text, typwriter, title 3D, and title cawl. Is that all of it? The link was an upgrade, so I wanted to check and see if I got everything.
Mark
Old December 15th, 2002, 10:34 AM   #1282
Warden
I think it was included in the upgrade, but maybe not. Look int the Extras folder and their should be one labeled Boris Calligraphy Docs. If there is, then it is included. Run the installer again and when Easy Install appears choose Custom instead and just check the Calligraphy box. That should allow you to just install the Caligraphy extras.
It might not have been included in the upgrade. In which case check out the Boris site http://www.borisfx.com/ I think they have some end of year deals going on.
Jeff
Old December 15th, 2002, 10:45 AM   #1283
Upgrade
There is a folder call Boris Caligraphy, but it's not the same package as the one on the full install of FCP3.0. It's kind of wierd but it's not the same package as the one Paul Sedillo has installed on his system from FCP 3.0 CD. I'll check the Boris site and maybe if I whine and howl enough they'll take pity on me and float me a full version of Boris :)
Old December 15th, 2002, 10:47 AM   #1284
Paul, thanks for your suggestion. I had checked out the filters on Joe's website before, but it seems that his mosaic filter doesn't allow you to complete the task using the filter alone; i.e., you have to copy the video clip to a second track, create a mask, apply the filter, and then animate the masked layer. I was wondering if a filter exists that allows you to apply a mosaic shape directly to the video clip and keyframe the motion entirely with the parameters of the filter.
Media Kobo
Japan
Rob Moreno is offline   Reply With Quote
Old December 15th, 2002, 10:56 AM   #1285
Warden
That's correct, because of the pricing difference between the upgrade and the full version. I doubt Boris will do much, maybe give a little extra off one of their products. It never hurts to ask.
Jeff
Old December 15th, 2002, 11:34 AM   #1286
Mark,
"Title 3D" is BC. Sounds like you have it now.
Old December 15th, 2002, 12:36 PM   #1287
I just downloaded
the patch from Apple it all seems to be working okay now. I can now mangle my text and titles even more than before :)
Mark
FYI: my email account seems to be messed up so if you send me anything make sure it goes to maustin1@houston.rr.com
Old December 15th, 2002, 10:49 PM   #1288
Rob,
Do you have a hard requirement for a mosiac or can you use a blur spot? If the latter, I know that Joe's Filters can do the job. Use the "Soft Spot" filter. You can easily keyframe its orgin in the footage. It doesn't require all of the monkey business you outlined.
Alternately, are you sure you can't get a signed release from the subject? <g?
Old December 15th, 2002, 11:18 PM   #1289
Thanks for the tip, Ken. The Soft Spot filter is more along the lines of what I am looking for, although I don't know if this project would allow me to subsitute mosaic with blur. I've been hired to shoot and edit an adult video for the Japnese market, and, as you may already know, in Japan all genitalia must be covered with mosaic. I've seen blur used instead of mosaic in pornographic magazines, but not in video. I'll need to research this.
Do you already own these filters, Ken? Do you know if you can animate the position of the blur by dragging it on the screen instead of entering in numerical values? Can you change the shape of the mask over time, or only the size? I guess I could just download the demo and find out, eh.
Media Kobo
Japan
Old December 15th, 2002, 11:29 PM   #1290
Rob,
Well I'd really like to help you reasearch this project but...I'm a married man <g>.
"Do you know if you can animate the position of the blur by dragging it on the screen instead of entering in numerical values? Can you change the shape of the mask over time, or only the size?"
(OK, I'm trying to evaluate your questions clinically rather than imagine how such attributes might be important for your project.)
Yes, you can change blur shapes and sizes over time. No, you must use numerical values to keyframe, as with other FCP.
Indeed, you should just download the demo filter set and experiment. That's what I did before I purchased. It's really a great value, particularly compared with other 1-trick-pony filter plug-ins that charge multiples of Joe's Filters.
Good luck with your project. Let us know if anything else, errr, comes up that we can help with.
