NLE Mac / Final Cut questions from 2002 - Page 84 at DVinfo.net
Final Cut Suite
Old December 8th, 2002, 04:50 PM   #1246
Jeff,
Thanks for the news! Just so that I understand what you've said..
As an 800 owner, in about 6 months time I should be able to purchase the Superdrive and replace my existing drive with it without changing the ribbon cable.
Amacitia Reddit Honores
(Friendship Brings Honour)
Guy Pringle
Silver Reflections
guypringle@yahoo.com
+27(0)83 256 8566
Guy Pringle is offline   Reply With Quote
Old December 8th, 2002, 05:20 PM   #1247
Warden
Guy, you are correct, Your 800MHz will not require a new ribbon cable. I doubt the drives will be available from Apple. I would get in contact with http://store.powerbook1.com/ and ask to be contacted when the new Superdrives become available.
Jeff
Old December 9th, 2002, 10:09 AM   #1248
Final Cut Pro Instruction
Thanks to all who responed to my request for opinions as to the best FCP instruction. As per one suggestion, I've ordered two CDs from DVCreators and will see how far I get. DCS
David C. Scott
David C. Scott is offline   Reply With Quote
Old December 9th, 2002, 06:39 PM   #1249
Guest
Posts: n/a
How is software RAID? I'm very distrustful of it both from a performance and a reliability standpoint. But that could be a viable creative solution to my problem.
-Aaron
Old December 9th, 2002, 07:26 PM   #1250
Warden
The very fact your doing a redundancy (RAID 1) your losing some performance. The software RAID will cost you some CPU cycles. I would not recommend it for rendering. You will have a decrease in performance. But for large swap files (Photoshop) or DV capture it will be barely noticed.
How are you planning to mount 5 drives in G4? Are you doing FireWire or SCSI and going external?
Jeff
Old December 10th, 2002, 01:07 PM   #1251
Guest
Posts: n/a
I have one of the new Mirror Macs which have 4 3.5inch slots plus I'm not using both 5.25inch slots, so that's 5.
RAID 10 makes up for some of the speed loss, especially in hardware implementations.
The thing I'm worried most about is the heat, though the Mirror Macs are also Wind Tunnels.
-Aaron
Old December 10th, 2002, 03:30 PM   #1252
jagged edges when rotating wireframe
Hello everyone
I reduced the size of my clip frame and rotated it by less than 45 degrees to give the final result a cartoon like look. The problem I have is the edges of the clip are now 'saw-tooth' like and along with a flickering makes the new look very difficult to watch. I noticed if I rotate the clip by exactly 45 degrees then these consequences disappear and it looks just like normal. The problem for me is that 45 degrees is too much rotation. I want less!
Is there a way to make those edges sharp again?
Cheers!
Simon
Simon Davies is offline   Reply With Quote
Old December 10th, 2002, 03:42 PM   #1253
Retired DV Info Net Almunus
Simon,
The problem you are seeing is called "aliasing" and it's common.
First off, what tool are you using? I assume you're using Final Cut Pro 3, but I don't want to assume so.
Next, are you observing this problem on your computer screen or on a television monitor?
Old December 10th, 2002, 04:25 PM   #1254
Jeff,
Got a reply from store.powerbook1. He figures once they've tested the Superdrive should be ready in as little as 2-3 months.
Guy Pringle
Silver Reflections
+27(0)83 256 8566
Old December 10th, 2002, 05:06 PM   #1255
Anti aliasing
Hi Ken
Thanks for the reply, I'm using FCP 3.0.2, OS X and I'm observing the problem both on the computer monitor and the small portable TV monitor I have too. Is there anything I can do?
Cheers!
Simon
Old December 10th, 2002, 05:24 PM   #1256
There's really no magic bullet to eliminate all of the jaggedness. I would first apply the "Anti-Alias" filter (found under Effects>Video Filters>Sylize). It has a default setting of "1". It will soften your image but it will also help to mitigate the jaggedness.
Render that out and inspect the results. Adjust to taste <g>.
When you're happy with that, and if your clip still has the "jitters" you can try the "Flicker Filter" (under Effects>Video Filters>Video). It basically adjusts the interlacing.
In general, it's best to shoot your original footage on angle (known as "dutch" shots) if you expect to use it on angle in post.
Good luck!
Old December 10th, 2002, 05:34 PM   #1257
OK I'll give that a go, thanks for your help Ken
Cheers!
Simon
Old December 10th, 2002, 10:31 PM   #1258
Warden
Here's some links on RAIDs and drives. Watch the age on some of the articles.
http://www.xlr8yourmac.com/IDE.html
http://www.barefeats.com/fire26b.html
http://www.barefeats.com/hard21.html
This will make for some interesting reading for you.
Jeff
Old December 11th, 2002, 01:03 AM   #1259
Kind of along those same lines..
Does anyone know of a card/system like the RTMac that allows both audio and video to be captured (FCP3 OSX)? Does the RTMac work in OSX yet? It's the only one I have heard about and it was supposed to allow a couple or real time transistions without rendering. Any other ideas how to get stuff in and out and reduce my render time? (I DON"T like to render!)
Mark
I'm humbled by the greatness that surrounds me.
Mark Austin is offline   Reply With Quote
Old December 11th, 2002, 01:21 AM   #1260
The RTMac still does not support OS-X. It only provided "real time" renders for certain effects anyway. The smart money is on FCP4 to provide a significant upgrade to its handling of effects rendering, so I'd sit tight for a while.
I don't really understand your question concerning capture. The RTMac simply provided a break-out box for composite analog.
