NLE Mac / Final Cut questions from 2002 - Page 69 at DVinfo.net
Final Cut Suite
Old November 2nd, 2002, 09:36 AM   #1021
Warden
From FCP choose export>Quicktime. One of the options in Quicktime is Toast format VCD. Burn the file in Toast>Other>Video CD.
Jeff
Old November 2nd, 2002, 12:04 PM   #1022
This is a ruthlessly newbie question, and I know I can find the answer by research, but I'm hoping someone will take pity on me. What is the relationship between the DVD encoding and the density of a commercial DVD and that possible on a DVD-R? Which codec available in Quicktime comes the closest to the commercial standard? From the comments above about submitting content to production facilities on DVD-R it sounds as if the compatibility is there, but are there relative length restrictions?
Thanks in advance for any info.
Linc Kesler
Linc Kesler is offline   Reply With Quote
Old November 2nd, 2002, 02:29 PM   #1023
What do people mean by "editing performance"? Rendering speed? Capture performance? ... As far as I know HD (>4000rpm)do not affect "editing performance". Processor speed , memory bandwidth and architecture, codec type, caches (L1 and L2) are the determining elements.
Andre De Clercq is offline   Reply With Quote
Old November 2nd, 2002, 05:36 PM   #1024
Warden
Editing performance is rendering, capture and more. FCP is scaleable, it will do
DV or uncompressed, even HD. So, depending on what your capturing a low performance (4000rpm) hard dive may, or may not be suitable. However, as we go up the scale the hard drive performance needs to improve. HD is usually done on FCP with SCSI RAID 0 and fiber optic controllers.
FCP has to render all its effects so the speed of the hard drive can have an impact there as well. I expect real time (RT) effects in future versions of FCP so the render times will become a mute point.
Some users report capture problems with the slower drives. It can be the result of many of the factors you list (memory, cache size, processor speed etc.). Many times it is the result of drives that need to be defragmented or are just too full. Faster drives sometimes can help out under those conditions.
Jeff
Old November 3rd, 2002, 03:54 AM   #1025
Agree if higher data rates (HD, video servers,vid on demand....) have to be in/outputted. Lots of the problems people get with "slow drives" in editing systems relate to non optimal tuning and hardware balancing of the system. Here http://www.wwug.com/forums/uleadmediastudio/index.htm is a site where rendering performance is being published. At the time it was created I discussed the HDD speed matter with Terry...turned out HDD speed not being relevant (and thus not included in the test results). Of course the test are not about FCP or MAC but the basics remain the same.
Old November 3rd, 2002, 11:41 AM   #1026
not in my fcp 3.0 it is. I cant find toast video cd under any of the options you have when exporting quiktime.
D.Slingerland
director/cameraman
http://www.slingerlandproductions.nl
David Slingerland is offline   Reply With Quote
Old November 3rd, 2002, 11:46 AM   #1027
Warden
I take it your not using OS X 10.1.5 ? What version of QuickTime and Toast are you using?
Jeff
Old November 3rd, 2002, 01:21 PM   #1028
thats right Jeff,
i am using os9 quicktime 6.0.2 and toast 5
if that is the reason then that is a big bummer
have you got any solutions?
D.Slingerland
director/cameraman
Old November 3rd, 2002, 03:13 PM   #1029
Warden
Go to my .mac iDisk http://homepage.mac.com/jtdonald/FileSharing5.htmland download a file called <<<make VCD on the mac.sit>>> Instructions are included and it will work on OS 9.
Jeff
Old November 3rd, 2002, 03:45 PM   #1030
Warden
Most commercial discs are very roughly 9 GB and DVD-R are roughly half that size. QuickTime does MPEG 2 multiplexing and is fairly fast but is not considered the best quality. It is a compromise of speed and quality. The very best (speed and quality) multiplexing is done via hardware. I believe Media 100 makes a board and so does Discret (see also Cleaner 6). Apple is rumored to be working on a board as well.
Jeff
Old November 4th, 2002, 10:19 PM   #1031
donking!
Posts: n/a
Edge Tear
I'm using Avid Xpress DV. I've been trying to output some footage to play as a Quicktime file. No matter what format for outputting that I choose, I get terrible edge tearing with motion on the output files. I don't see this in the composer window in XDV. Any suggestions?
On close inspection what's happening is that two out of every five frames it looks like the interlaced fields are not lined up with each other. So it goes: 3 good sharp frames, then 2 out of mesh frames, then 3 good sharp frames, the 2 out of mesh frames, etc.
Old November 5th, 2002, 05:38 AM   #1032
FCP external video sync problem
Folks:
I have a project in FCP that I cannot get to send proper video out. My setup (FCP3.02, dual G4 with Jaguar, Panasonic DV1000 and Toshiba monitor) and all other projects done on it over the past several months work fine...it's just this project that won't fly. The video just jumps around on the monitor from the very first frame whenever I try to watch it just as external video or print to video. Parts of the sequence will sync up and run fine. Other parts will not; and I lose external audio whenever the video goes out of sync.
I have tried every setting related to external video I can find, but that doesn't seem to be it. It seems like the project file itself is corrupted somehow. A file output to FCP movie from this sequence runs fine in QT PLayer, but will not re-load into FCP as a single source (fails with a 'general error' message). I have tried cutting and pasting into a new sequence. I have suspected something wrong with some of the source files, although they all look fine and the sequence plays solid end-to-end within FCP itself. But I recaptured some of the sources anyway, to no avail. I tried moving sources around onto different drives in case it related to some kind of bus congestion problem, to no avail.
So... anyone out there bumped into this before?
Dave Sweet is offline   Reply With Quote
Old November 5th, 2002, 06:54 AM   #1033
thank you jeff. I downloaded the file but vcd jelly does not take any quiktime files it keeps telling me that they are a file of unknown type, anyway it will not process it. So i cant use the japanese program because that will also not accept quicktime files coming from fcp. However i got toast to accept my fcp files(it was simple actually)but my big files i output(550mb) because i want the best quality on cd are reduced by toast to a mere 26 mb. The quality is not exactly what i tought it was going to be.... i have got better vhs tapes then that!!
any suggestions about improving the quality?
thanks,
D.Slingerland
director/cameraman
Old November 5th, 2002, 07:10 AM   #1034
Warden
Can you please provide complete details about system, OS, drives, software versions etc.
Jeff
Old November 5th, 2002, 07:39 AM   #1035
Warden
Have you updated to the latest version 3.5.1? It has many bug fixes.
Jeff
